Need Help with TBS6985 Driver Only
Re: Need Help with TBS6985 Driver Only
Postby Cpoc » Sun Jan 12, 2014 12:19 pm
After installing dvbhdhomerun and the ivtv drivers tvheadend will not see either of them in the config. It will ONLY see the 4 TBS 6985 adapters and my hdhomerun and PVR 500 is not listed. That's my issue
Here is my output of lsmod
Module Size Used by
dvb_hdhomerun_core 12483 0
loop 22641 0
tbsfe 12425 4
tbs6985fe 21981 4
radeon 718093 1
tuner_simple 17175 2
tuner_types 16409 1 tuner_simple
wm8775 12749 3
rc_tbs_nec 12396 0
saa716x_tbs_dvb 54408 0
ttm 53664 1 radeon
tda9887 12645 1
ir_lirc_codec 12719 0
tbs6982fe 21981 1 saa716x_tbs_dvb
lirc_dev 17031 1 ir_lirc_codec
tda8290 17278 0
drm_kms_helper 31370 1 radeon
ir_mce_kbd_decoder 12615 0
tbs6680fe 17177 1 saa716x_tbs_dvb
drm 183952 3 drm_kms_helper,ttm,radeon
tbs6923fe 21981 1 saa716x_tbs_dvb
tbs6985se 17489 1 saa716x_tbs_dvb
tbs6928se 17489 1 saa716x_tbs_dvb
ir_sony_decoder 12435 0
tbs6982se 21981 1 saa716x_tbs_dvb
ir_jvc_decoder 12433 0
tbs6991fe 17452 1 saa716x_tbs_dvb
tbs6618fe 17177 1 saa716x_tbs_dvb
saa716x_core 39763 1 saa716x_tbs_dvb
i5000_edac 12828 0
edac_core 35258 3 i5000_edac
ir_rc6_decoder 12433 0
tbs6922fe 21981 1 saa716x_tbs_dvb
tuner 17497 4
tbs6928fe 17452 1 saa716x_tbs_dvb
ir_rc5_decoder 12433 0
tbs6991se 17489 1 saa716x_tbs_dvb
stv090x 42943 1 saa716x_tbs_dvb
dvb_core 77733 2 saa716x_core,saa716x_tbs_dvb
ir_nec_decoder 12433 0
cx25840 39826 3
power_supply 13475 1 radeon
rc_core 18329 10 ir_nec_decoder,ir_rc5_decoder,ir_rc6_decoder,ir_jvc_decoder,ir_sony_decoder,ir_mce_kbd_decoder,ir_lirc_codec,saa716x_tbs_dvb,rc_tbs_nec
ivtv 129124 0
cx2341x 21461 1 ivtv
tveeprom 20593 1 ivtv
iTCO_wdt 17081 0
iTCO_vendor_support 12704 1 iTCO_wdt
v4l2_common 13222 5 cx2341x,ivtv,cx25840,tuner,wm8775
videodev 70902 6 v4l2_common,cx2341x,ivtv,cx25840,tuner,wm8775
v4l2_compat_ioctl32 16567 1 videodev
media 18148 1 videodev
ioatdma 37440 6
i2c_algo_bit 12841 3 ivtv,saa716x_tbs_dvb,radeon
i5k_amb 12923 0
snd_pcm 68083 0
snd_page_alloc 13003 1 snd_pcm
snd_timer 22917 1 snd_pcm
snd 52889 2 snd_timer,snd_pcm
soundcore 13065 1 snd
psmouse 69265 0
serio_raw 12931 0
rng_core 12652 0
pcspkr 12579 0
evdev 17562 5
i2c_i801 16870 0
dca 13240 1 ioatdma
i2c_core 23876 30 i2c_i801,i2c_algo_bit,videodev,v4l2_common,tveeprom,ivtv,cx25840,stv090x,tbs6991se,tbs6928fe,tuner,tbs6922fe,tbs6618fe,tbs6991fe,saa716x_core,tbs6982se,tbs6928se,tbs6985se,tbs6923fe,drm,tbs6680fe,drm_kms_helper,tda8290,tbs6982fe,tda9887,saa716x_tbs_dvb,wm8775,tuner_simple,radeon,tbs6985fe
coretemp 12898 0
shpchp 31293 0
processor 28157 0
button 12937 0
container 12581 0
thermal_sys 18040 1 processor
ext4 350763 1
crc16 12343 1 ext4
jbd2 62115 1 ext4
mbcache 13114 1 ext4
sg 25874 0
sd_mod 36136 3
crc_t10dif 12348 1 sd_mod
uhci_hcd 26865 0
ahci 24997 2
libahci 22860 1 ahci
libata 140630 2 libahci,ahci
ehci_hcd 40215 0
usbcore 128741 3 ehci_hcd,uhci_hcd
usb_common 12354 1 usbcore
aacraid 72148 0
scsi_mod 162269 4 aacraid,libata,sd_mod,sg
e1000e 120822 0
root@tvheadend:~#
As you see dvb_hdhomerun_core is not being used. If I install only dvbhdhomerun and ivtv both show up in tvheadend config.
Please help I'm stuck........
Cpoc
Postby Cpoc » Wed Jan 22, 2014 11:05 pm
To close this thread I will make my last post. Their is no solution to my problem. Since TBS installs its own v4l tree it installs different versions of lots of files and drivers including dvb-core which does not work when you install other hardware that needs compiling. ie.. hdhomerun. The solutions is to run tbs on another server and then you can install any tbs hardware and works fine. My solution was to simply move the tbs card to my nextpvr backend which was running hauppage hdpvr2 and install the windows drivers instead. It seems to work fine. On my Linux server I have hauppage PVR500 and hdhomerun working perfectly.
Cpoc
Postby updatelee » Wed Jan 22, 2014 11:56 pm
That driver must not be in the tbs tree.
Previous
