OpenELEC 5.0.4
Re: OpenELEC 5.0.4
Postby otipep2000 » Fri Jun 05, 2015 9:39 am
Hi, I have it installed and it's running pretty well. My only issue is that the unit runs hot (150F) and the CPU fan does not kick in. Should I worry or is this fine? Also, is there a recommended usb wifi adapter? I appreciate your work. Cheers!
otipep2000
Re: OpenELEC 5.0.4
Postby vpeter » Fri Jun 05, 2015 3:01 pm
For fan create a file /storage/.config/imx6-soc-fan-monitor.conf. There should already be sample file named imx6-soc-fan-monitor.conf.sample. Change the values and change high value to 60 for example. Then fan will start at 60 degrees celsius (140F).
Wifi adapter: I assume same as for RPi. Something with Linux support.
vpeter
Re: OpenELEC 5.0.4
Postby jimmyx » Sat Jun 06, 2015 10:43 am
vpeter Wrote:For fan create a file /storage/.config/imx6-soc-fan-monitor.conf. There should already be sample file named imx6-soc-fan-monitor.conf.sample. Change the values and change high value to 60 for example. Then fan will start at 60 degrees celsius (140F).
sadly for some reason I do not have this sample file.. would it be possible for some kind person to post the the sample /storage/.config/imx6-soc-fan-monitor.conf This would be much appreciated
Thank you for your awesome work vpeter :D
jimmyx
Re: OpenELEC 5.0.4
Postby vpeter » Sat Jun 06, 2015 2:41 pm
In ssh console run
cp /usr/config/imx6-soc-fan-monitor.conf.sample /storage/.config/imx6-soc-fan-monitor.conf
Or create it in Windows over samba. The content is
# imx6-soc-fan-monitor.conf.sample - i.MX6 SoC fan monitor config file
#   used only for TBS Matrix system
# default limits without config file
# when fan is turned on
#   high=70
# when fan is turned off
#   low=60
# temperature checking interval
#   interval=30
# periodically show temperature
#   debug=no
high=70
low=55
interval=30
debug=no
vpeter
Re: OpenELEC 5.0.4
Postby jimmyx » Sun Jun 07, 2015 12:50 am
vpeter Wrote:In ssh console run
#   high=70
#   low=60
#   interval=30
#   debug=no
high=70
low=55
interval=30
debug=no
for some reason the above will turn my fan on when it hits those temps...
I had to put this in the autostart.sh file in order for the fan to ever turn on, otherwise the fan will not turn on after a reboot
echo "echo default-on > /sys/class/leds/fan/trigger" >>/storage/.config/autostart.sh
is there a way I could combine the two? Ideally id like the fan to only come on when needed, instead of running FULL Speed ALL the time
jimmyx
Re: OpenELEC 5.0.4
Postby vpeter » Sun Jun 07, 2015 1:02 am
Don't use trigger directly. Instead put in autostart.sh this command
 systemctl restart imx6-soc-fan-monitor
It should already be start by default but there are some timing issues. Will be fixed in next version.
vpeter
Re: OpenELEC 5.0.4
Postby jimmyx » Sun Jun 07, 2015 4:15 am
vpeter Wrote:Don't use trigger directly. Instead put in autostart.sh this command
thank you, however it seems my unit does not want to cooperate today :/
(exists I created it)
I added the line systemctl restart imx6-soc-fan-monitor to the autostart and rebooted... no fan. Then I tried manually running the command
OpenELEC:~ # systemctl restart imx6-soc-fan-monitor
Failed to restart imx6-soc-fan-monitor.service: Unit imx6-soc-fan-monitor.service failed to load: No such file or directory.
OpenELEC:~ #
sorry to be such a pain, i guess ill just go back to having the fan run all the time. this unit has been problematic when it comes to the fan and openelec
jimmyx
Re: OpenELEC 5.0.4
Postby vpeter » Sun Jun 07, 2015 2:27 pm
Tell me first which openelec version are you using? Because it seems you don't use 5.0.8 v1 or 5.95.1 v2. Only there this works.
I already suspected that because you didn't have fan config sample.
vpeter
Re: OpenELEC 5.0.4
Postby jimmyx » Mon Jun 08, 2015 2:00 pm
I am using the 5.0.4 but I updated it through the update feature to 5.0.8
I will reinstall 5.0.8 from scratch, I take it the auto update feature updates with an official openelec and not your matrix modded openelec ?
jimmyx
Re: OpenELEC 5.0.4
Postby vpeter » Mon Jun 08, 2015 2:45 pm
Yes, autoupdate install official version. But maybe new v6 beta will have everything inside.
vpeter
PreviousNext
Return to Announcements
Users browsing this forum: No registered users and 13 guests
