Low Symbol Rates(Solved)
Postby Ratchet1966 » Mon Aug 29, 2011 3:23 am
Hi, I recently purchased a Q-Box 5980 and I am mostly pleased with it. I have an issue, however, with low sybol rate transponders. I can't seem to lock anything under 2Msps in a viewer app such as DVB Viewer, DVB Dream, AltDVB etc. The TBS 5980 blind scan software can detect the transponders but I am unable to scan them in any of the viewer apps. I know the signal is fine as I have STBs that can get these low SR channels. Is this a known issue and is there a driver update due in the near future ? I am using Windows 7 64bit with the latest driver 1.0.0.9 connected to Intel ICH10 USB 2.0 host controller. Any help would be appreciated, thanks.
Ratchet1966
Re: Low Symbol Rates
Postby bob » Tue Aug 30, 2011 1:47 pm
Could you please show me the which satellite you are recieving? I'd like to know the low symbole rate frequency detail,so i can reproduce the problem in our lab.
Best regards!
bob
Postby Ratchet1966 » Tue Aug 30, 2011 2:32 pm
Here are some examples of the TPs that blind scan can find but the viewer apps cannot.
11.0W Express AM44
11507 H 1240 DVB-S2 8PSK 2/3
11521 H 1817 DVB-S QPSK 7/8
11548 H 1599 DVB-S QPSK 2/3
12.5W Atlantic Bird 1
12528 V 1299 DVB-S QPSK 3/4
12682 V 1707 DVB-S2 QPSK 3/5
Ratchet1966
Postby bob » Wed Aug 31, 2011 5:04 pm
Please download the version driver for TBS5980,link: http://hotfile.com/dl/128484322/49d34b9 ... 1.rar.html
i had fixed the low symbo rates problem inside the driver.
BTW,if input the low symbo rates,it will take long time wait for lock,you can input 0 for symbol rates,the driver will do the blind scan with the single frequency,very fast.
And i had fixed other bugs,which will cause app hang up.
Please make a test and give me the result,i will keep improved the drivers for you.
bob
Postby Ratchet1966 » Wed Aug 31, 2011 5:41 pm
Hi, thanks for the quick turn around with this. I'll test this out later today and let you know how I get on.
Ratchet1966
Postby Ratchet1966 » Thu Sep 01, 2011 12:44 am
Just tested the new driver and so far so good. I even managed to get a lock on 12748 H 716 QSPK 1/2 on Atalantic Bird 2 8.0W even although this is below the official range of the device (1000 - 45000) :)
I also think that the blind scan is considerably quicker than before. :P
Once again many thanks for the very prompt fix, much appreciated.
Screen cap of Low SR on 8.0W
Ratchet1966
