Modules do not show up
Postby brutus2675 » Fri Jun 14, 2013 8:56 pm
Having made a clean install of Mageia 3, I ran through the requirements for installing the tbs-6280 drivers:
1) Ensured the kernel headers / source were installed.
2) uname -a returned 3.8.13-desktop-1.mga3
3) from linux-tbs-drivers:
a) ran # rm -rf /lib/modules/3.8.13-desktop-1.mga3/kernel/drivers/media/
b) then: # ./v4l/tbs-x86_64.sh, Noted positive response.
c) ran: make
d) ran: make install
e) ren: shutdown -r now
On return, the TV card failed to show up in demsg and the drivers failed to appear in lsmod.
What could be causing this?
brutus2675
Re: Modules do not show up
Postby updatelee » Fri Jun 14, 2013 9:00 pm
before doing make do a sudo make menuconfig and confirm that the modules your interested in are selected.
did you see any error's during the entire process?
Re: Modules do not show up [SOLVED]
Postby brutus2675 » Sun Jun 16, 2013 5:23 am
Without doing anything new other than having powered off completely for 24 hours, everything showed up and I have TV!
I must remember that this has been a solution to similar problems in the past.
Sorry for troubling you.
brutus2675
