Installer le pilote de la tbs 6980 / Install the driver tbs
Postby xunil2003 » Mon Jan 26, 2015 10:29 pm
French
Bonjour,
Je susis sur Linux Ubuntu 14.04 LTS x64.
J'e posséde une carte tv TBS 6280.
lspci
04:00.0 Multimedia controller: Philips Semiconductors SAA7160 (rev 03)
05:00.0 Multimedia controller: Philips Semiconductors SAA7160 (rev 02)
Je suis sur le noyau
laurent@Laurent-Bureau:~$ uname -r
3.13.0-44-generic
J'ai télécgargé le fichier :
tbs-linux-drivers_v150109.zip
Une fois le pilote installer et l pc rebooter , quand fait :
dmesg | grep frontend
[   48.104223] saa716x_core: disagrees about version of symbol dvb_frontend_detach
[   48.104224] saa716x_core: Unknown symbol dvb_frontend_detach (err -22)
[   48.104229] saa716x_core: disagrees about version of symbol dvb_unregister_frontend
[   48.104230] saa716x_core: Unknown symbol dvb_unregister_frontend (err -22)
[   48.104233] saa716x_core: disagrees about version of symbol dvb_register_frontend
[   48.104234] saa716x_core: Unknown symbol dvb_register_frontend (err -22)
[   48.104292] saa716x_core: disagrees about version of symbol dvb_frontend_detach
[   48.104293] saa716x_core: Unknown symbol dvb_frontend_detach (err -22)
[   48.104298] saa716x_core: disagrees about version of symbol dvb_unregister_frontend
[   48.104299] saa716x_core: Unknown symbol dvb_unregister_frontend (err -22)
[   48.104302] saa716x_core: disagrees about version of symbol dvb_register_frontend
[   48.104303] saa716x_core: Unknown symbol dvb_register_frontend (err -22)
ls /dev/dvb
ls: impossible d'accéder à /dev/dvb: Aucun fichier ou dossier de ce type
Pour l'installation, j'ai fait ceci :
cd ~/linux-tbs-drivers
sudo ./v4l/tbs-x86_64.sh
sudo make TARGET=x86_64-elf
sudo make install
Merci.
English
I Susis 14.04 LTS Ubuntu Linux on x64.
J'e has a tv TBS 6280 card.
lspci
I'm on the core
3.13.0-44-generic
I downloaded the file :
After the driver install and reboot the PC when done :
ls /dev/dvb
ls: can not access  /dev/dvb: No such file or folder of this type
To install, I did this :
sudo make install
thank you.
xunil2003
Re: Installer le pilote de la tbs 6980 / Install the driver
Postby petyanamlt » Mon Feb 16, 2015 8:32 am
The same problem, help to correct,
opensuse 13.2 x64 system
kernel 3.16.7
[ 3.179246] saa716x_core: disagrees about version of symbol dvb_frontend_detach
[ 3.179248] saa716x_core: Unknown symbol dvb_frontend_detach (err -22)
[ 3.179256] saa716x_core: disagrees about version of symbol dvb_unregister_frontend
[ 3.179257] saa716x_core: Unknown symbol dvb_unregister_frontend (err -22)
[ 3.179263] saa716x_core: disagrees about version of symbol dvb_register_frontend
[ 3.179264] saa716x_core: Unknown symbol dvb_register_frontend (err -22)
petyanamlt
