bugreport. tbs6284 stops working
Postby rickyticky » Thu Apr 11, 2013 4:21 pm
Hi, my tbs6284 recording in non-stop mode, and it fails once at one-two days.
kernel: 3.0.69-std-def-alt0.M60P.1 #1 SMP Thu Mar 14 23:57:49 UTC 2013 x86_64 GNU/Linux
tbs driver: v130318
After this errors in kernel log recording stops, and fixing only after reboot:
Apr 11 04:49:53.83 tm1 kernel: [141130.348812] irq 32: nobody cared (try booting with the "irqpoll" option)
Apr 11 04:49:53.83 tm1 kernel: [141130.348817] Pid: 0, comm: swapper Tainted: P            3.0.69-std-def-alt0.M60P.1 #1
Apr 11 04:49:53.83 tm1 kernel: [141130.348819] Call Trace:
Apr 11 04:49:53.83 tm1 kernel: [141130.348821]  <IRQ>  [<ffffffff810c78e5>] __report_bad_irq+0x35/0xd0
Apr 11 04:49:53.83 tm1 kernel: [141130.348831]  [<ffffffff810c7cc6>] note_interrupt+0x126/0x1e0
Apr 11 04:49:53.83 tm1 kernel: [141130.348835]  [<ffffffff81364d80>] ? napi_gro_flush+0x50/0x50
Apr 11 04:49:53.83 tm1 kernel: [141130.348838]  [<ffffffff810c5eda>] handle_irq_event_percpu+0xba/0x1f0
Apr 11 04:49:53.83 tm1 kernel: [141130.348841]  [<ffffffff810c6045>] handle_irq_event+0x35/0x60
Apr 11 04:49:53.83 tm1 kernel: [141130.348843]  [<ffffffff810c85ae>] handle_fasteoi_irq+0x6e/0x110
Apr 11 04:49:53.83 tm1 kernel: [141130.348847]  [<ffffffff8100d2b4>] handle_irq+0x44/0xa0
Apr 11 04:49:53.88 tm1 kernel: [141130.348850]  [<ffffffff8100cf38>] do_IRQ+0x58/0xe0
Apr 11 04:49:53.88 tm1 kernel: [141130.348855]  [<ffffffff8141b893>] common_interrupt+0x13/0x13
Apr 11 04:49:53.88 tm1 kernel: [141130.348858]  [<ffffffff8141b893>] common_interrupt+0x13/0x13
Apr 11 04:49:53.88 tm1 kernel: [141130.348860]  [<ffffffff81364d80>] ? napi_gro_flush+0x50/0x50
Apr 11 04:49:53.88 tm1 kernel: [141130.348875]  [<ffffffffa034cc80>] ? igb_poll+0x7c0/0xd80 [igb]
Apr 11 04:49:53.88 tm1 kernel: [141130.348878]  [<ffffffff810cbb89>] ? rcu_irq_exit+0x9/0x10
Apr 11 04:49:53.88 tm1 kernel: [141130.348882]  [<ffffffff810635a8>] ? irq_exit+0x48/0xb0
Apr 11 04:49:53.88 tm1 kernel: [141130.348885]  [<ffffffff8100cf41>] ? do_IRQ+0x61/0xe0
Apr 11 04:49:53.88 tm1 kernel: [141130.348888]  [<ffffffff8141b893>] ? common_interrupt+0x13/0x13
Apr 11 04:49:53.88 tm1 kernel: [141130.348891]  [<ffffffff81364f51>] net_rx_action+0x141/0x260
Apr 11 04:49:53.88 tm1 kernel: [141130.348895]  [<ffffffff81063265>] __do_softirq+0xa5/0x1c0
Apr 11 04:49:53.88 tm1 kernel: [141130.348899]  [<ffffffff814243dc>] call_softirq+0x1c/0x30
Apr 11 04:49:53.88 tm1 kernel: [141130.348902]  [<ffffffff8100d375>] do_softirq+0x65/0xa0
Apr 11 04:49:53.88 tm1 kernel: [141130.348905]  [<ffffffff810635ee>] irq_exit+0x8e/0xb0
Apr 11 04:49:53.88 tm1 kernel: [141130.348908]  [<ffffffff8100cf41>] do_IRQ+0x61/0xe0
Apr 11 04:49:53.88 tm1 kernel: [141130.348911]  [<ffffffff8141b893>] common_interrupt+0x13/0x13
Apr 11 04:49:53.88 tm1 kernel: [141130.348912]  <EOI>  [<ffffffff81081aed>] ? __hrtimer_start_range_ns+0x19d/0x480
Apr 11 04:49:53.88 tm1 kernel: [141130.348921]  [<ffffffff8129ab82>] ? intel_idle+0xc2/0x120
Apr 11 04:49:53.88 tm1 kernel: [141130.348924]  [<ffffffff8129ab64>] ? intel_idle+0xa4/0x120
Apr 11 04:49:53.88 tm1 kernel: [141130.348928]  [<ffffffff81345d74>] cpuidle_idle_call+0xb4/0x230
Apr 11 04:49:53.88 tm1 kernel: [141130.348932]  [<ffffffff8100a1e6>] cpu_idle+0x56/0xa0
Apr 11 04:49:53.88 tm1 kernel: [141130.348935]  [<ffffffff81404b6d>] rest_init+0x6d/0x80
Apr 11 04:49:53.88 tm1 kernel: [141130.348940]  [<ffffffff81881bc4>] start_kernel+0x374/0x37f
Apr 11 04:49:53.88 tm1 kernel: [141130.348943]  [<ffffffff81881347>] x86_64_start_reservations+0x132/0x136
Apr 11 04:49:53.88 tm1 kernel: [141130.348946]  [<ffffffff8188144c>] x86_64_start_kernel+0x101/0x110
Apr 11 04:49:53.88 tm1 kernel: [141130.348948] handlers:
Apr 11 04:49:53.88 tm1 kernel: [141130.348952] [<ffffffffa01d6550>] saa716x_tbs6284_pci_irq
Apr 11 04:49:54.76 tm1 kernel: [141131.279769] irq 16: nobody cared (try booting with the "irqpoll" option)
Apr 11 04:49:54.76 tm1 kernel: [141131.279837] handlers:
Apr 11 04:49:54.76 tm1 kernel: [141131.279848] [<ffffffffa01ea2c0>] usb_hcd_irq
Apr 11 04:49:54.76 tm1 kernel: [141131.279773] Pid: 0, comm: swapper Tainted: P            3.0.69-std-def-alt0.M60P.1 #1
Apr 11 04:49:54.76 tm1 kernel: [141131.279775] Call Trace:
Apr 11 04:49:54.76 tm1 kernel: [141131.279776]  <IRQ>  [<ffffffff810c78e5>] __report_bad_irq+0x35/0xd0
Apr 11 04:49:54.76 tm1 kernel: [141131.279783]  [<ffffffff810c7cc6>] note_interrupt+0x126/0x1e0
Apr 11 04:49:54.76 tm1 kernel: [141131.279787]  [<ffffffff8129ab82>] ? intel_idle+0xc2/0x120
Apr 11 04:49:54.76 tm1 kernel: [141131.279790]  [<ffffffff810c5eda>] handle_irq_event_percpu+0xba/0x1f0
Apr 11 04:49:54.76 tm1 kernel: [141131.279793]  [<ffffffff810c6045>] handle_irq_event+0x35/0x60
Apr 11 04:49:54.76 tm1 kernel: [141131.279795]  [<ffffffff810c85ae>] handle_fasteoi_irq+0x6e/0x110
Apr 11 04:49:54.76 tm1 kernel: [141131.279799]  [<ffffffff8100d2b4>] handle_irq+0x44/0xa0
Apr 11 04:49:54.76 tm1 kernel: [141131.279802]  [<ffffffff8100cf38>] do_IRQ+0x58/0xe0
Apr 11 04:49:54.76 tm1 kernel: [141131.279806]  [<ffffffff8141b893>] common_interrupt+0x13/0x13
Apr 11 04:49:54.76 tm1 kernel: [141131.279808]  <EOI>  [<ffffffff81081aed>] ? __hrtimer_start_range_ns+0x19d/0x480
Apr 11 04:49:54.76 tm1 kernel: [141131.279814]  [<ffffffff8129ab82>] ? intel_idle+0xc2/0x120
Apr 11 04:49:54.76 tm1 kernel: [141131.279817]  [<ffffffff8129ab64>] ? intel_idle+0xa4/0x120
Apr 11 04:49:54.76 tm1 kernel: [141131.279820]  [<ffffffff81345d74>] cpuidle_idle_call+0xb4/0x230
Apr 11 04:49:54.76 tm1 kernel: [141131.279824]  [<ffffffff8100a1e6>] cpu_idle+0x56/0xa0
Apr 11 04:49:54.76 tm1 kernel: [141131.279826]  [<ffffffff81404b6d>] rest_init+0x6d/0x80
Apr 11 04:49:54.76 tm1 kernel: [141131.279829]  [<ffffffff81881bc4>] start_kernel+0x374/0x37f
Apr 11 04:49:54.76 tm1 kernel: [141131.279833]  [<ffffffff81881347>] x86_64_start_reservations+0x132/0x136
Apr 11 04:49:54.76 tm1 kernel: [141131.279836]  [<ffffffff8188144c>] x86_64_start_kernel+0x101/0x110
Sometimes i see this error, but recording still works fine after it.
The attachment function on forum does not works, so:
dmesg: http://pastebin.com/download.php?i=1C7idGM3
lspci: http://pastebin.com/download.php?i=eEcp8fkH
lsusb: http://codepad.org/itYfeTWX
rickyticky
Re: bugreport. tbs6284 stops working
Postby cody » Thu Apr 11, 2013 7:11 pm
please, look how to solve the problem here:
viewtopic.php?f=52&t=7631#p24903
the post there is for 6280, but it applies for 6284 too.
Postby rickyticky » Thu Apr 11, 2013 7:55 pm
Thank you!
rickyticky
