TBS Drivers failing on ubuntu kernel 3.2.0-58
Postby joolzg » Tue Feb 04, 2014 4:12 pm
I have this in my dmesg with source tbs-linux-drivers-v140113.zip
from dmesg
tbs6928fe: module license "Turbosight Proprietary: www.tbsdtv.com" taints kernel
saa716x_tbs_dvb: unknown symbol i2c_bit_add_bus (err 0)
uname -a
Linux joe15 3.2.0-58-generic #88-Ubuntu SMP Tue Dec 3 17:37:58 UTC 2013 x86_64 x86_64 x86_64 GNU/Linux
joolz
joolzg
Re: TBS Drivers failing on ubuntu kernel 3.2.0-58
Postby cody » Tue Feb 04, 2014 5:46 pm
that's not fault of our drivers - it seems like I2C support in your kernel is disabled. so, rebuild your kernel with I2C support enabled.
Postby joolzg » Tue Feb 04, 2014 5:52 pm
was working on the previous version of kernel!
All i did was a dist-upgrade
joolz
joolzg
Postby updatelee » Wed Feb 05, 2014 12:00 am
Did you re install the tbs driver after?
