Card not seen after successful compile on 4.3.3 Kernel?
Postby pinsb » Wed Jan 27, 2016 6:08 pm
Kernel 4.3.3-301 Fedora Core 23 x86_64.
This is a new build on a new box.
Card IS seen by hardware (please note although I'm showing this with the 6280 card it applies to both the 6280 and 6284 - I had to put the 6284 back into the production box).
>:lspci -vv -s 2:00.0
02:00.0 Multimedia controller: Philips Semiconductors SAA7160 (rev 03)
Subsystem: Device 6280:0011
Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Interrupt: pin A routed to IRQ 10
Region 0: Memory at f7b00000 (64-bit, non-prefetchable) [disabled] [size=1M]
Address: 0000000000000000 Data: 0000
LnkCap: Port #1, Speed 2.5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <4us, L1 <64us
ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp-
LnkCtl: ASPM Disabled; RCB 128 bytes Disabled- CommClk-
Kernel modules: saa716x_tbs_dvb
No problems during the compile (I've done this stuff before)
TBS Driver Version 151229
Tried swapping the cards into different slots...no difference.
dmesg does not report the card at all (suggesting driver issue).
Any ideas?
pinsb
Re: Card not seen after successful compile on 4.3.3 Kernel?
Postby pinsb » Wed Jan 27, 2016 6:13 pm
Just noticed that the download link is saying driver 160126
however the file downloaded is 151229.zip
caching issue on your server?
pinsb
Postby cody » Wed Jan 27, 2016 6:21 pm
pinsb Wrote:Just noticed that the download link is saying driver 160126
yes, on this, we will fix it ASAP. on the issue, please, provide full dmesg log first..
Postby pinsb » Wed Jan 27, 2016 6:37 pm
Cody
Don't want to post full dmesg here....
OK if I post it to euro support mail address?
pinsb
Postby pinsb » Wed Jan 27, 2016 7:39 pm
Cody
I've emailed both the dmesg and the more expansive journalctl for the boot.
Pls just confirm you have received if you could.
Regards
pinsb
