[SOLVED] device not found
Postby brutus2675 » Fri Apr 08, 2016 6:04 am
Having successfully compiled the latest driver for my tbs-6280 yesterday, I fully expected everything to run smoothly.
I now find that kaffeine returns 'device not found' and mythtv says 'all tuners are busy'.
I re-ran make install to see again what the depmod line looked like and it looked OK
A susequent dmesg search revealed this:
[ 6.614306] saa716x_core: disagrees about version of symbol dvb_dmxdev_init
[ 6.614310] saa716x_core: Unknown symbol dvb_dmxdev_init (err -22)
[ 6.614356] saa716x_core: disagrees about version of symbol dvb_register_adapter
[ 6.614358] saa716x_core: Unknown symbol dvb_register_adapter (err -22)
[ 6.614384] saa716x_core: disagrees about version of symbol dvb_dmx_release
[ 6.614386] saa716x_core: Unknown symbol dvb_dmx_release (err -22)
[ 6.614393] saa716x_core: disagrees about version of symbol dvb_net_init
[ 6.614395] saa716x_core: Unknown symbol dvb_net_init (err -22)
[ 6.614400] saa716x_core: disagrees about version of symbol dvb_dmxdev_release
[ 6.614401] saa716x_core: Unknown symbol dvb_dmxdev_release (err -22)
[ 6.614407] saa716x_core: disagrees about version of symbol dvb_frontend_detach
[ 6.614409] saa716x_core: Unknown symbol dvb_frontend_detach (err -22)
[ 6.614413] saa716x_core: disagrees about version of symbol dvb_net_release
[ 6.614415] saa716x_core: Unknown symbol dvb_net_release (err -22)
[ 6.614420] saa716x_core: disagrees about version of symbol dvb_unregister_frontend
[ 6.614421] saa716x_core: Unknown symbol dvb_unregister_frontend (err -22)
[ 6.614426] saa716x_core: disagrees about version of symbol dvb_register_frontend
[ 6.614427] saa716x_core: Unknown symbol dvb_register_frontend (err -22)
What is my best bet now?
brutus2675
Re: device not found
Postby SergioDanielG » Fri Apr 08, 2016 11:04 pm
Hi brutus2675
Did you select correct script to your pc and did you remove all from kernel media before install new version?
This is a common problem if you didn't.
Kind regards.
SergioDanielG
Postby brutus2675 » Sun Apr 10, 2016 4:00 pm
I thought I had cleared the ¬/media folder and created the driver correctly as no errors were reported.
However, I removed all unwanted kernels and ran it all again although I did download an even fresher driver set before I started.
That worked but after while I again got 'device not found'.
I then remembered having vacuumed the box before installing the new operating system.
I removed the TBS-6280 and examined it before returning it to the box.
It has now behaved well for about 12 hours so I reckon that cracked it.
Thank you for your help.
brutus2675
