Home > Products > TBS TV Tuner USB > DVB-T2 > TBS5881 DVB-T2/T/C TV Tuner CI USB box
    TBS5881 USB DVB-T2/T/C TV Box CI is a hybrid TV tuner box built with Common Interface support, which allows you to watch and recode Free to Air/Clear TV programmers also can watch and recode encrypt programmers via insert correct CAM and smartcard in its CI slot. There are one DVB-T2/T TV tuner and the other DVB-C TV tuner for you to choose between digital Terrestrial TV Channel and digital Cable TV Channel. The appropriate software to be provided such as: MediaPortal and its plugins, you may stream terrestrial and cable TV contents to your iPhone, iPad or iPod.
    • Watch digital TV & listen to radio on PC
    • Recode digital TV programmers on PC
    • CI slot for insert CAM and smart card to decrypt the encrypted Pay TV
    • Connect with USB
    • DVB-T2/T/C SD or HD TV receiving
    • Real time and scheduled program recording (PVR)
    • Time shifting to pause live TV
    • Common Interface (CI) Support
