Home > Products > TBS TV Tuner PCIe > ISDB-T > TBS6209 DVB-T2/C2/T/C/ISDB-T/Clear QAM Octa TV Tuner
    TBS6209 is a DVB-T2/C2/T/C/ISDB-T/Clear QAM cable TV Octa tuner card with PCI-Express interface, it can be used for watching eight different channels from eight different frequencies simultaneously, and it supports both DVB-T2 and DVB-C2 standard at the same time.
    TBS6209 DVB-T2/C2/T/C/ISDB-T/Clear QAM cable TV Octa tuner card works also as a digital video recorder for recording digital terrestrial TV programs with full HDTV support. TBS6209 is considered as a professional TV tuner for industrial-level users. When the PCIe slot in the server is limited, TBS6209 enables you to receive more channels than the usual dual or quad TV tuner. Thus it is highly recommended for broadcasting system.
    • DVB-T2/C2/T/C/ISDB-T/Clear QAM SD or HD TV receiving
    • Octa channel receiving simultaneously
    • High-definition video, real-Time and scheduled video
    • Recording
    • High sensitivity DVB-T2 octa Tuner for the best digital TV reception
