Home > Products > TBS TV Tuner PCIe > Multi-Standard > TBS6528 Multi Standard Tv Tuner CI PCI-e Card
    TBS6528 is a PCI Express TV tuner card that supports multiple digital TV standards, including DVB-S2/S, DVB-T2/T,DVB-C2/C, DVB-S2X and ISDB-T. It is built with Common Interface which allows insertion of CAM and smartcard for pay TV, so it is a good choice for watching/recording digital cable HD TV on PC. With this multi-standard TV tuner card, it is much easier to switch between different digital TV signals. You just need to plug another signal cable instead of taking out the card from your server.
    View More
    • Support DVB-S/S2/S2X, DVB-T/T2/C(ITU-T J.83 Annex A/B/C)/C2, ISDB-T
    • Watch & record TV/ radio programs on PC
    • Common Interface (Single CI) Support
    • SD or HD TV receiving
    • Data receiving
    • Media monitoring
