Home > Products > TBS TV Tuner PCIe > Multi-Standard > TBS6590 Multi Standard Dual Tuner Dual CI PCI-e Card
    TBS6590 multi standard dual tuner dual CI card is a twin tuner card for watching or recording two different channels from two different frequencies simultaneously. TBS6590 supports multiple digital TV standards, including DVB-S2/S, DVB-T2/T,DVB-C2/C, DVB-S2X and ISDB-T. It is built with 2 Common Interface which allows insertion of CAM and smartcard for pay TV, so it is a good choice for watching/recording digital HD TV on PC. What's more, with this multi-standard TV tuner card, it is much easier to switch between different digital TV signals, you just need to plug another signal cable instead of taking out the card from your server.
    • Support DVB-S/S2/S2X, DVB-T/T2/C(ITU-T J.83 Annex A/B/C)/C2, ISDB-T
    • Watch & record TV/ radio programs on PC
    • Common Interface (Dual CI) Support
    • SD or HD TV receiving
    • Data receiving
    • Media monitoring
