Home > Products > TBS TV Tuner PCIe > DVB-S2X > TBS6908 Professional DVB-S2 Quad Tuner PCIe Card
    TBS6908 is a Professional level digital satellite TV Tuner card with PCI Express interface. TBS6908 supports not only normal DVB-S2/DVB-S QPSK, 8PSK which is supported by normal satellite receivers, but also supports CCM, ACM, VCM, Multi Input Stream, 16APSK, 32APSK, Generic Stream Mode , which most satellite receiving devices can't support. With use of dedicated TBS tools, those special streams can be captured. Both Windows BDA driver and Linux driver up to the latest kernel 3.X are ready.
    TBS6908 Professional DVB-S2 Quad Tuner PCIe Card has the highest industry standard. Its outstanding reliability is what any personal enthusiast or engineer in the digital satellite TV industry wants. The applying of an unique DVB-S2 demodulator chipset makes it possible to receive special streams broadcasted with ACM, VCM, Multi Input Stream, 16APSK, 32APSK or Generic Stream Mode.
    • EUMETCast Compatibility
    • Quad tuner DVB-S2/S transponders receiving
    • CCM, VCM, ACM and Multi Input Stream support
    • Generic stream mode Support
    • Up to 190 Mbit/s channel bit rate capture
    • Wide range symbol rates support from 1Msps to 45Msps
    • Unicable/one cable compatible
    • Blindscan
    • High reliability
    • Satellite feed hunt
    • Satellite data download
    • Lock of special transponders
