Home > Products > IP-ASI/ASI-IP > TBS690A 4 Input DVB-ASI Capture Card
    TBS690A is a DVB-ASI capture card with 4 channels input, which used to receive DVB transport streams up to 270 Mbps/channel on one card, and the transport streams can be single programs or multi programs. TBS690A is ideal for high-density applications requiring up to four ASI inputs, the input channels can run independently. With minimal power consumption, TBS690A is tailored for industrial applications where reliability is an option.
    • DVB-ASI input
    • Compatible with DVB Standard
    • Four receiver channels on the same PCI-e card
    • Full DVB-ASI throughput of 140 Mbps per channel
    • Bandwidth can be divided as required between the ports
    • Signal quality sensing support in hardware
    • IPTV Servers
    • ASI to IP conversion
    • Datacasting and monitoring
    • Electronic Program Guides (EPG's)
    • Broadcast TV
