Home > Products > TBS TV Tuner PCIe > DVB-S2X > TBS6910 DVB-S2 Dual Tuner Dual CI PCIe Card
    TBS6910 DVB-S2 Dual Tuner Dual CI PCIe Card is a twin tuner digital satellite TV for watching or recording two different channels from two different frequencies simultaneously. You can use one tuner to watch TV channel while using another tuner to record/watch another channel from another transponder/ satellite at same time. TBS6910 is integrated with two CI slots, inserting the correct CAM and subscription smartcard into the CI slot makes it possible to watch encrypted pay TV.
    Main Features
    • Watch satellite TV & listen to radio on PC
    • DVB-S/S2 SD or HD TV receiving
    • Dual tuner and dual CI slots for decrypt the encrypted TV
    • Time shifting to pause live TV
    • Blindscan support
    • Unicable/one cable compatible
    Application
    • Data receiving
    • IPTV streaming
    • Media monitoring
