TBS8922 PCI DVB-S2 TV Tuner Card
TBS8922 is a PCI interface digital satellite TV Tuner card for watching and recording Free to Air satellite TV on PC. It supports both DVB-S2 and DVB-S programs receiving. It’s ready with Windows BDA driver and Linux driver up to the latest kernel 3.X(Tested on Ubuntu,Fedora,Opensuse and other Linux distributions). It’s compatible with Windows7 Media Center, MediaPortal, DVBlink, DVBDream, DVBViewer, ProgDVB, Skynet, TSreader, XBMC,MythTV,VDR and many other popular softwares.
- Description
- Specification
- Picture
- User Guide
TBS8922 PCI DVB-S2 TV Tuner card is the latest release of TBS PCI series satellite TV cards. It’s built with the highest quality components such as tantalum capacitors. You can use it to watch UK Freesat or any other satellite TV programs in your region. With its’ low profile size, it’s ideal for building up HTPC or IPTV server. The built in hardware blindscan capability allows you to scan satellite programs without knowing exact transponder details, this is especially useful for satellite feed hunting.
Watch Satellite TV & listen to Radio on PC
DVB-S2/DVB-S SD or HD TV Receiving
Broadband Internet via Satellite *
High-speed Data download via Satellite *
Unicable/One Cable compatible
Blindscan
High reliability
*Depends on service provider.
HTPC
IPTV Streaming Server
Specifications:
Receiving Frequency: 950~2150 MHz Tuning Range
Input level: -69~-23dBm
DVB-S2/DVB-S DIRECTV 8PSK QPSK Demodulator
Symbol Rate:
DVB-S QPSK 1~45Msps
DVB-S2 QPSK/8PSK 1~45Msps
Carrier Capture Range: ±10MHz
8PSK Puncture codes: 3/5,2/3,3/4,5/6,8/9,9/10
QPSK Puncture codes: 1/2,3/5,2/3,3/4,4/5,5/6,8/9,9/10.
Support Data Burst & Tone Burst
Support DiSEqC2.X and Motor
Low profile size: 143x56mm (Length x Height)
System Requirements:
Windows 2000/XP/Vista/7 or Linux
DirectX9.0 or later Version
Available PCI slot
Satellite Dish and LNB
For DVB-S:
1GHz CPU or above
256MB RAM or above
Graphic Card with at least 16MB RAM
For DVB-S2 HDTV:
Dualcore CPU
1GB RAM or Above
Package Content:
1 x TBS8922 PCI-E DVB-S2 TV Tuner Card
1 x remote control
1 x IR receiver
1 x Software CD
