Oscam + TVheadend (or another client)
Postby gfi » Sat May 25, 2013 8:34 pm
I see, users have a problem with local connections between oscam (as newcamd server) and TVheadend (client).
So, little QaA help you, I hope.
Q: Why TVheadened can't connect to 127.0.0.1 (oscam server)?
A: I wrote about that on 08.05.2013.
viewtopic.php?f=93&t=8494&p=28908&hilit=ifconfig#p28908
"Look at ifconfig, will see why. Missing Loopback setting for 'localhost'. You can try setup of eth0 with other params. I haven't time yet, but I'll looking ..."
So, step by step:
add (or create) loopback setup with Your network start.
for test:
over SSH type:
ifconfig lo 127.0.0.1
check loopback setting:
type:
ifconfig lo
or simple ifconfig and You need to see something like that:
# ifconfig
eth0 Link encap:Ethernet HWaddr 00:22:AB:90:00:47
inet addr:192.168.1.188 Bcast:0.0.0.0 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:422683 errors:0 dropped:0 overruns:0 frame:0
TX packets:893559 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:28980883 (27.6 MiB) TX bytes:1303630807 (1.2 GiB)
Interrupt:41
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:1368 errors:0 dropped:0 overruns:0 frame:0
TX packets:1368 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:102022 (99.6 KiB) TX bytes:102022 (99.6 KiB)
In /etc/hosts is loopback already defined.
Note: missing broadcast, if someone need broadcast, send me PM.
Q: How to setup connection over camd.socket
A: As You need, but You can't keeping anonymous connection on dvbapi section.
(You need to define user, what already exist).
Also, please be careful with camd.socket, control Your reader (in oscam webif), if EMM instructions comming over camd.socket setup.
gfi
Return to FAQ
