by edz2k11 » Wed Jun 08, 2011 8:37 am
Hi there
I'm afraid I dont have a solution but I have the same problem!
Running under ubuntu I've added an 8920 to replace a nova dvb-s card since BBC HD have moved to DVB-S2. Unfortunately its not proving to be a very good choice at the moment!
The card now seems to be being picked up but I cant get it to scan.
I'm on Ubuntu 10.04 LTS
uname -ar
Code:
Linux Tardis 2.6.32-32-generic #62-Ubuntu SMP Wed Apr 20 21:54:21 UTC 2011 i686 GNU/Linux
Running dmesg | grep cx88
gives me
Code:
[ 21.223415] cx88/2: cx2388x MPEG-TS Driver Manager version 0.0.8 loaded
[ 21.223774] cx88[0]: subsystem: 8920:8888, board: TBS 8920 DVB-S/S2 [card=72,autodetected], frontend(s): 1
[ 21.223778] cx88[0]: TV tuner type 4, Radio tuner type -1
[ 21.418732] cx88/0: cx2388x v4l2 driver version 0.0.8 loaded
[ 23.884163] input: cx88 IR (TBS 8920 DVB-S/S2) as /devices/pci0000:00/0000:00:0a.2/rc/rc0/input5
[ 23.884256] rc0: cx88 IR (TBS 8920 DVB-S/S2) as /devices/pci0000:00/0000:00:0a.2/rc/rc0
[ 23.884262] cx88[0]/2: cx2388x 8802 Driver Manager
[ 23.884295] cx88-mpeg driver manager 0000:00:0a.2: PCI INT A -> GSI 18 (level, low) -> IRQ 18
[ 23.884305] cx88[0]/2: found at 0000:00:0a.2, rev: 5, irq: 18, latency: 32, mmio: 0xec000000
[ 23.884315] IRQ 18/cx88[0]: IRQF_DISABLED is not guaranteed on shared IRQs
[ 23.884939] cx8800 0000:00:0a.0: PCI INT A -> GSI 18 (level, low) -> IRQ 18
[ 23.884952] cx88[0]/0: found at 0000:00:0a.0, rev: 5, irq: 18, latency: 32, mmio: 0xeb000000
[ 23.884966] IRQ 18/cx88[0]: IRQF_DISABLED is not guaranteed on shared IRQs
[ 23.885072] cx88[0]/0: registered device video0 [v4l2]
[ 23.885107] cx88[0]/0: registered device vbi0
[ 25.471492] cx88/2: cx2388x dvb driver version 0.0.8 loaded
[ 25.471498] cx88/2: registering cx8802 driver, type: dvb access: shared
[ 25.471504] cx88[0]/2: subsystem: 8920:8888, board: TBS 8920 DVB-S/S2 [card=72]
[ 25.471509] cx88[0]/2: cx2388x based DVB/ATSC card
[ 25.471512] cx8802_alloc_frontends() allocating 1 frontend(s)
[ 26.186765] DVB: registering new adapter (cx88[0])
Which looks ok although I'm not sure its loading the firmware.
Trying to scan doesnt work though, using
scan -x0 -a1 Astra*28*E
gives lots of these messages
Code:
WARNING: filter timeout pid 0x0010
and kern.log shows
Code:
Jun 7 20:11:36 Tardis kernel: [ 48.020054] cx24116_cmd_execute() Firmware not responding
Jun 7 20:11:38 Tardis kernel: [ 49.292089] cx24116_cmd_execute() Firmware not responding
Jun 7 20:11:39 Tardis kernel: [ 50.564041] cx24116_cmd_execute() Firmware not responding
Jun 7 20:13:31 Tardis kernel: [ 162.388013] cx24116_cmd_execute() Firmware not responding
Jun 7 20:13:39 Tardis kernel: [ 170.408025] cx24116_cmd_execute() Firmware not responding
Jun 7 20:13:40 Tardis kernel: [ 171.444032] cx24116_cmd_execute() Firmware not responding
Jun 7 20:13:41 Tardis kernel: [ 172.520015] cx24116_cmd_execute() Firmware not responding
Jun 7 20:14:00 Tardis kernel: [ 191.556015] cx24116_cmd_execute() Firmware not responding
Jun 7 20:14:01 Tardis kernel: [ 192.632015] cx24116_cmd_execute() Firmware not responding
Once thing I've also noted is that the instructions say to run
apt-get install linux-kernel-devel
which you cant do under newer ubuntu builds. I've tried alternatives but wonder if this is why its not working as expected!
Sadly if emails to tbs dont work and I cant find a solution soon, this 8920 will be winging its way back to Amazon and hauppauge will be getting more business
