no signal channels not found in TBS8920 in kernel 2.6.35-rc
Postby temocles0918 » Tue Jul 06, 2010 12:21 pm
Its necesary other driver for this kernel 2.6.35?. The file linux-tbs-all no compile.. Someone idea? thanks
temocles0918
Re: no signal channels not found in TBS8920 in kernel 2.6.3
Postby cody » Tue Jul 06, 2010 2:03 pm
hi, did you install firmware file in your Linux system? it should work with official V4L code like i explained for TBS 6920 here:
viewtopic.php?f=6&t=45#p222
are there any errors reported after you get to lock/scan transponder? please, check this with:
# dmesg | grep cx88
# dmesg | grep 24116
Postby temocles0918 » Wed Jul 07, 2010 11:35 am
Hi, thanks
>>hi, did you install firmware file in your Linux system? it should work with official V4L code like i explained for TBS 6920 here:>
Yes, i copy firmware dvb-fe-cx24116.fw to /lib/firmware..
dmesg
lo: Disabled Privacy Extensions
eth0: no IPv6 routers present
cx24116_firmware_ondemand: Waiting for firmware upload (dvb-fe-cx24116.fw)...
cx24116_firmware_ondemand: Waiting for firmware upload(2)...
cx24116_load_firmware: FW version 1.23.86.1
cx24116_firmware_ondemand: Firmware upload complete
<< are there any errors reported after you get to lock/scan transponder? please, check this with:
# dmesg | grep cx88
# dmesg | grep 24116 >>
Yes... in dmesg
cx88/0: cx2388x v4l2 driver version 0.0.8 loaded
cx88/2: cx2388x MPEG-TS Driver Manager version 0.0.8 loaded
cx8800 0000:06:02.0: PCI INT A -> GSI 18 (level, low) -> IRQ 18
cx88[0]: subsystem: 8920:8888, board: TBS 8920 DVB-S/S2 [card=72,autodetected], frontend(s): 1
cx88[0]: TV tuner type 4, Radio tuner type -1
input: cx88 IR (TBS 8920 DVB-S/S2) as /devices/pci0000:00/0000:00:1e.0/0000:06:02.0/rc/rc0/input6
rc0: cx88 IR (TBS 8920 DVB-S/S2) as /devices/pci0000:00/0000:00:1e.0/0000:06:02.0/rc/rc0
cx88[0]/0: found at 0000:06:02.0, rev: 5, irq: 18, latency: 32, mmio: 0xde000000
cx88[0]/0: registered device video1 [v4l2]
cx88[0]/0: registered device vbi1
cx88[0]/2: cx2388x 8802 Driver Manager
cx88-mpeg driver manager 0000:06:02.2: PCI INT A -> GSI 18 (level, low) -> IRQ 18
cx88[0]/2: found at 0000:06:02.2, rev: 5, irq: 18, latency: 32, mmio: 0xdf000000
cx88/2: cx2388x dvb driver version 0.0.8 loaded
cx88/2: registering cx8802 driver, type: dvb access: shared
cx88[0]/2: subsystem: 8920:8888, board: TBS 8920 DVB-S/S2 [card=72]
cx88[0]/2: cx2388x based DVB/ATSC card
cx8802_alloc_frontends() allocating 1 frontend(s)
DVB: registering new adapter (cx88[0])
dmesg |grep cx24116
DVB: registering adapter 0 frontend 0 (Conexant CX24116/CX24118)...
In kaffeine show me "Tunning failed"... I test card in windows with the same transporter and work!!!... its stranger with Linux...
Thanks by reply.. Regards..
temocles0918
Postby cody » Wed Jul 07, 2010 12:17 pm
hi, thank you for providing additional information. it seems i will need to test with kernel 2.6.35-rc, because your logs doesn't indicate any error(s) and your test in Windows shows that your TBS 8920 is working and your dish, cables, etc are setup correctly. please, give me several days time to check TBS 8920 with kernel 2.6.35-rc.
