Installing to Ubuntu 13.10
Postby twosheds » Mon Nov 25, 2013 1:41 am
I'm trying to get my card to work with Ubuntu 13.10. It's working prefectly under Windows 7 (I'm dual booting the one machine with the card installed) but it's not installing properly as the output from the dmesg ¦ grep cx88
shows
[ 9.724389] cx88xx: disagrees about version of symbol btcx_riscmem_alloc
[ 9.724393] cx88xx: Unknown symbol btcx_riscmem_alloc (err -22)
[ 9.724399] cx88xx: disagrees about version of symbol btcx_riscmem_free
[ 9.724401] cx88xx: Unknown symbol btcx_riscmem_free (err -22)
[ 9.724549] cx88xx: disagrees about version of symbol btcx_riscmem_alloc
[ 9.724552] cx88xx: Unknown symbol btcx_riscmem_alloc (err -22)
[ 9.724558] cx88xx: disagrees about version of symbol btcx_riscmem_free
[ 9.724559] cx88xx: Unknown symbol btcx_riscmem_free (err -22)
I think that the problem lies in the fact that the command ( given in the README)
apt-get install linux-kernel-devel
does't install linux-kernel-devel as it can't find it
Can anyone advise me what I need to do to get the install to work correctly ?
Regards
twosheds
Re: Installing to Ubuntu 13.10
Postby updatelee » Mon Nov 25, 2013 7:27 am
This has been covered in the past, imo it would be nice to have it as a sticky to prevent people from asking once a week
Youve got some old modules mixed in with the new ones.
sudo mv /lib/modules/$(uname -r)/kernel/drivers/media ~/media.bak
sudo make install
sudo reboot
Postby twosheds » Fri Nov 29, 2013 8:06 pm
Worked like a charm. Thank you for your advice.
twosheds
