TBS6985 119mbit Fotelka
Postby nev77 » Mon Jul 18, 2022 3:19 am
I have TBS6985 and test it in windows xp with all drivers 1.0.0.0 to 1.0.0.5. I have artefacts on fotelka transponder with 119mbit stream
Belintersat 1 11230.00 H - Europe DVB-S2 8PSK 45000 8/9.
Another transponder works very well.
Belintersat 1 11350.00 H - Europe DVB-S2 8PSK 45000 3/4
Test od all 4 ports and use external power too - same problem. I use it in linux ubuntu 22 with latest tbs open linux drivers, but same problem.
Card works pretty well with SR 999 on this tranponder
Astra 3B 11675.00 V 12 Europe DVB-S2 8PSK 999 3/4
It looks like a hardware problem of the card, let alone that I had to run it on the old hardware from 2007 because on the newer gigabyte there is a problem with detection and sometimes it is, sometimes it is not there. However, I knew that such a problem exists, by the way someone solved and fixed it?
Linux syslog on this transponder
Jul 18 13:51:38 tbss tvheadend.tvheadend[699]: 2022-07-18 13:51:38.599 [WARNING] tbl-eit: eit: 11230H in 51,5E: invalid checksum (len 490, errors 265)
Jul 18 13:51:42 tbss tvheadend[699]: tbl-base: cat: 11230H in 51,5E: invalid checksum (len 24, errors 8)
Jul 18 13:51:42 tbss tvheadend.tvheadend[699]: 2022-07-18 13:51:42.837 [WARNING] tbl-base: cat: 11230H in 51,5E: invalid checksum (len 24, errors 8)
Jul 18 13:51:43 tbss tvheadend[699]: tbl-base: pat: 11230H in 51,5E: invalid checksum (len 168, errors 25)
Jul 18 13:51:43 tbss tvheadend.tvheadend[699]: 2022-07-18 13:51:43.579 [WARNING] tbl-base: pat: 11230H in 51,5E: invalid checksum (len 168, errors 25)
Jul 18 13:51:46 tbss tvheadend[699]: tbl-base: bat: 11230H in 51,5E: invalid checksum (len 962, errors 4)
Jul 18 13:51:46 tbss tvheadend.tvheadend[699]: 2022-07-18 13:51:46.156 [WARNING] tbl-base: bat: 11230H in 51,5E: invalid checksum (len 962, errors 4)
Jul 18 13:51:46 tbss tvheadend[699]: tbl-base: sdt: 11230H in 51,5E: invalid checksum (len 520, errors 26)
Jul 18 13:51:46 tbss tvheadend.tvheadend[699]: 2022-07-18 13:51:46.750 [WARNING] tbl-base: sdt: 11230H in 51,5E: invalid checksum (len 520, errors 26)
Jul 18 13:51:48 tbss tvheadend[699]: tbl-eit: eit: 11230H in 51,5E: invalid checksum (len 198, errors 303)
Jul 18 13:51:48 tbss tvheadend.tvheadend[699]: 2022-07-18 13:51:48.569 [WARNING] tbl-eit: eit: 11230H in 51,5E: invalid checksum (len 198, errors 303)
Jul 18 13:51:53 tbss tvheadend[699]: tbl-base: pat: 11230H in 51,5E: invalid checksum (len 168, errors 32)
Jul 18 13:51:53 tbss tvheadend.tvheadend[699]: 2022-07-18 13:51:53.996 [WARNING] tbl-base: pat: 11230H in 51,5E: invalid checksum (len 168, errors 32)
Jul 18 13:51:55 tbss tvheadend[699]: tbl-base: nit: 11230H in 51,5E: invalid checksum (len 509, errors 3)
Jul 18 13:51:55 tbss tvheadend.tvheadend[699]: 2022-07-18 13:51:55.006 [WARNING] tbl-base: nit: 11230H in 51,5E: invalid checksum (len 509, errors 3)
Jul 18 13:51:57 tbss tvheadend[699]: tbl-base: sdt: 11230H in 51,5E: invalid checksum (len 997, errors 30)
Jul 18 13:51:57 tbss tvheadend.tvheadend[699]: 2022-07-18 13:51:57.719 [WARNING] tbl-base: sdt: 11230H in 51,5E: invalid checksum (len 997, errors 30)
Jul 18 13:51:58 tbss tvheadend[699]: tbl-eit: eit: 11230H in 51,5E: invalid checksum (len 196, errors 343)
Jul 18 13:51:58 tbss tvheadend.tvheadend[699]: 2022-07-18 13:51:58.803 [WARNING] tbl-eit: eit: 11230H in 51,5E: invalid checksum (len 196, errors 343)
nev77
