TVHeadend + xbmc strong artifacts
Re: TVHeadend + xbmc strong artifacts
Postby LubosD » Tue Feb 04, 2014 7:10 am
My broken setup is also based on an ASUS motherboard: ASUS P8Z77-V LX + Intel Core i5.
LubosD
Postby C0dR » Thu Feb 06, 2014 2:21 am
Well, good to hear that I am at least not alone with this problem. I think the problem lies on the linux drivers. Because on WIndows I had no artifacts with the exact same hardware (installed windows on a second HDD). I read somewhere on this forum that it might be something with the buffer size or something like that.
C0dR
Postby BeMax » Fri Feb 07, 2014 6:51 am
I have tested the buffer and IRQ trick without any improvments...
BeMax
Postby jandenouden » Sun Feb 09, 2014 5:25 am
Ok, since you say it works fine under Windows I guess the Linux driver is the culprit (haven't tried Windows myself). This also explains why so many people with different motherboards are all seeing this problem.
It would be nice if TBS could make a statement about this problem; TBS support have always been very helpful, but it seems this is a problem that support can't get to the bottom of.
Jan
jandenouden
Postby kvaster » Mon Jul 14, 2014 6:12 pm
I'm suffering from this issues also. The only difference is that it's all OK with hd channels in case I disable all adapters except one. Please help to fix the problem...
kvaster
Postby BeMax » Fri Aug 15, 2014 2:25 pm
kvaster wrote:I'm suffering from this issues also. The only difference is that it's all OK with hd channels in case I disable all adapters except one. Please help to fix the problem...
How do you disable three tuners and just use one ?
BeMax
Postby Krobaruk » Mon Dec 15, 2014 8:49 pm
For me I find putting the CPU under stress actually fixes the problem. I don't understand how this fixes the problem for me but try:
"stress -c 1"
TBS,
Any idea where the problem might be? Could it be the "Relaxed Ordering Bit" PCI setting? Disabling CPU frequency changes does not help.
Krobaruk
Previous
