I am not a linux expert but have adapted the Ubuntu How To Compile guide and the instructions given by http://www.havetheknowhow.com/Configure-the-server/Install-Tuner.html plus info from the mess of readme's contained in the driver package (helpfully the 6982 has no specific readme!). Simply copy and paste the code lines below into the terminal and run for success. I think this guide should work for any of the drivers contained in the same driver zip. I am not sure why tbs requires you to choose your specific card from the list as there seems to be a common package for all of them? This guide has many steps, but I have included everything so that new linux users should have no problems.
First off we need to prep our system for building packages.
- Code: Select all
sudo apt-get install build-essential checkinstall unzip linux-generic linux-headers-generic linux-source
You should then create a common directory for yourself where you'll be building these packages. Ubuntu recommend creating the directory /usr/local/src for compiling tasks.
- Code: Select all
sudo mkdir /usr/local/src
Make sure this directory is writable by your primary user account.
- Code: Select all
sudo chown YOURUSERNAME /usr/local/src
And to ensure you have the correct permissions.
- Code: Select all
sudo chmod u+rwx /usr/local/src
Now go to that directory.
- Code: Select all
cd /usr/local/src
Now download the driver (When a new driver gets released the following line will need to be changed to the new driver).
- Code: Select all
wget http://www.tbsdtv.com/download/document/common/tbs-linux-drivers_v150728.zip
Create a directory for unzipping the download to.
- Code: Select all
mkdir tbs150728
And unzip it to the directory we just created.
- Code: Select all
unzip tbs-linux-drivers_v150728.zip -d tbs150728
And go to the directory.
- Code: Select all
cd tbs150728
Please note that the permissions of the unzipped files won't be the same as we set earlier. Each time you unpack a compressed file they would need to be re-established, as I am not going to do this several of the following commands will require sudo to work.
Although firmware is considered optional in all the readme files, in theory the ones supplied by tbs should be best suited to the drivers. As this guide is tentatively for other cards that use this driver package copy all the firmware files to the correct location. You may omit this step if you choose.
- Code: Select all
sudo cp -i *.fw /lib/firmware
You will be asked if you wish to overwrite two of them, you will be asked if you wish to overwrite all of them when repeating this step after this. Please note this step will need to be repeated when a system update of the 'linux-firmware' package happens. I will explain this further down the page when I cover reinstalling.
Unpack the driver package.
- Code: Select all
sudo tar xjvf linux-tbs-drivers.tar.bz2
Go to driver package directory.
- Code: Select all
cd linux-tbs-drivers
When building most packages the command to use at this point would be ./configure, however in this case you need to run one of three potential choices, depending on your system. As this guide is for Ubuntu 15.04 the choice is really between two of these, because 15.04 uses a 3.x kernel.
- Code: Select all
uname -a
For x86 kernel 3.x
- Code: Select all
sudo ./v4l/tbs-x86_r3.sh
OR
For x86_64 kernel.
- Code: Select all
sudo ./v4l/tbs-x86_64.sh
It will report back to you that the driver is configured for your previous choice. I have a x86_64 machine so from now on all the commands will reflect this. Now we can build and install the driver.
- Code: Select all
sudo make
This process will take a while, make yourself a well earned beverage of your choice. Once completed instead of 'make install' we do.
- Code: Select all
sudo checkinstall
The first time you build the driver it will complain about no man documentation and ask if generic docs can be created select yes. Then it will ask you to enter a description. I usually put
- Code: Select all
TBS Linux Drivers
Following this a menu will pop up where you can configure options for the install. I suggest editing the version number. You must start the version number with a numerical value.
- Code: Select all
150728
When finished let checkinstall continue. Checkinstall will simulate the make install process, bundle all the files up into a .deb for us and try to install it. However as some of the files in our created .deb need to overwrite files from other packages the checkinstall process will error after the creation of our .deb. This means we will have to force dpkg to overwrite those files. The checkinstall process has created a file in the folder we are in called linux-tbs_150728-1_amd64.deb.
- Code: Select all
sudo dpkg -i --force-overwrite linux-tbs_150728-1_amd64.deb
That completes the install, you can now reboot your computer and should have a working card!
When a system upgrade of the firmware package or the kernel happens these drivers need to be rebuilt. The system update will probably fail, moaning that files belonging to our tbs package need to be overwritten. It is simplest to remove our package.
- Code: Select all
sudo apt-get purge linux-tbs
Then complete your system update. After this make sure you are in the correct directory.
- Code: Select all
cd /usr/local/src/tbs150728/linux-tbs-drivers
Remove our created package.
- Code: Select all
sudo rm linux-tbs_150728-1_amd64.deb
And then reset the driver build.
- Code: Select all
sudo make distclean
Now return to the step above where we chose our architecture and repeat the rest of the steps again.
That concludes my guide, good luck to you all. If you have any improvements or spot any mistakes please point them out. I believe that checkinstall can pass arguments to dpkg, but I have not mastered this yet. Also dkms, which you might be aware of if you have an nvidia graphics card, could potentially handle automatic rebuilding of a driver when the kernel is updated. At this point this is beyond my skill level.
