Capture Full Transport Stream
Postby controloye » Mon Oct 26, 2015 3:37 am
I have purchased TBS6982 card because it was mention on website that card will capture whole transponder stream.
I am able to capture single channel by following command:
szap-s2 -a1 -l C-BAND -p -r "GEO"
and result is
reading channels from file '/root/.szap/channels.conf'
zapping to 11 'GEO':
sat 0, frequency 4180 MHz V, symbolrate 26666000, coderate auto, rolloff 0.35
mis -1, vpid 0x0065, apid 0x00c9, sid 0x0001
using '/dev/dvb/adapter1/frontend0' and '/dev/dvb/adapter1/demux0'
status 1f | signal 7706 | snr e9cf | ber 03ffff00 | unc 00000000 | FE_HAS_LOCK
status 1f | signal c6db | snr 81b4 | ber 00000000 | unc 00000000 | FE_HAS_LOCK
status 1f | signal c6fb | snr 8369 | ber 00000000 | unc 00000000 | FE_HAS_LOCK
and I can record using following command.
cat /dev/dvb/adapter1/dvr0 > new.ts
and result is
root@Call:~# avconv -i new.ts
[mpegts @ 0x110d5e0] PES packet size mismatch
Last message repeated 1 times
Guessed Channel Layout for Input Stream #0.1 : stereo
Input #0, mpegts, from 'new.ts':
Duration: 00:00:04.58, start: 52170.770989, bitrate: 4346 kb/s
Program 2
Program 3
Program 4
Program 5
Program 6
Program 7
Program 8
Program 10
Program 1
Stream #0.0[0x65]: Video: mpeg2video (Main), yuv420p, 720x576 [PAR 16:15 DAR 4:3], 15000 kb/s, 25 fps, 25 tbr, 90k tbn, 50 tbc
Stream #0.1[0xc9](eng): Audio: mp2, 48000 Hz, stereo, s16p, 128 kb/s
Program 9
Program 11
which shows there are 11 channels in whole stream but I can not capture whole stream. Then I visited following page :
http://www.linuxtv.org/wiki/index.php/Szap
where it is clearly written
" The szap tool can not enable multiple video streams in a DVB-S transport stream."
I need help that how can I capture / record all channels with one transponder stream.
thanks
controloye
Re: Capture Full Transport Stream
Postby xiaocao » Mon Oct 26, 2015 2:30 pm
hi ,
you can use mumudvb to record ts packets.
this is the context in configuration file
card=1
freq=12538
srate=27500
pol=V
coderate=auto
lnb_slof=11700
lnb_lof_low=9750
lnb_lof_high=10600
common_port=1234
autoconfiguration=full
use the following command to record.
mumudvb -d -c mumudvb.conf --dumpfile new.ts
best regards !
xiaocao
Postby controloye » Tue Oct 27, 2015 10:57 pm
Thank you xiaocao for quick reply.
can you please tell me configuration for AsiaSat 3S - 105.5° East
card = 1
freq = 4180
srate = 26666
pol = V
coderate = auto
lnb_slof = ?????
lnb_lof_low = ?????
lnb_lof_high = ?????
common_port = ?????
autoconfiguration = ?????
controloye
