- Code: Select all
[ 5.922771] DVB: registering new adapter (Terratec Cinergy T USB XXS (HD)/ T3)
[ 5.963407] DVB: registering new adapter (SAA716x dvb adapter)
[ 6.169885] DVB: registering adapter 0 frontend 0 (DiBcom 7000PC)...
[ 6.407855] input: IR-receiver inside an USB DVB receiver as /devices/pci0000:00/0000:00:14.0/usb1/1-6/rc/rc1/input21
[ 6.407918] rc1: IR-receiver inside an USB DVB receiver as /devices/pci0000:00/0000:00:14.0/usb1/1-6/rc/rc1
[ 6.501713] TurboSight TBS6928SE DVB-S2 card MAC=00:22:ab:e0:5a:ef
[ 6.524143] DVB: registering adapter 1 frontend 0 (TurboSight TBS 6928SE DVBS/S2 frontend)...
[ 13.785038] dvb_ca adapter 1: DVB CAM detected and initialised successfully
Also lspci -v
- Code: Select all
01:00.0 Multimedia controller: Philips Semiconductors SAA7160 (rev 03)
Subsystem: Device 6928:0002
Flags: bus master, fast devsel, latency 0, IRQ 16
Memory at df200000 (64-bit, non-prefetchable) [size=1M]
Capabilities: <access denied>
uname -a
- Code: Select all
Linux htpc 4.2.0-27-generic #32-Ubuntu SMP Fri Jan 22 04:49:08 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
I created a scan file
- Code: Select all
[email protected]:~$ cat file
# Astra 19.2E SDT info service transponder
# freq pol sr fec
S 11302750 H 22000000 2/3 AUTO 8PSK
running scan-s2 fails:
- Code: Select all
[email protected]:~$ scan-s2 -a 1 file -v
API major 5, minor 3
ERROR: Cannot open rotor configuration file 'rotor.conf'.
scanning file
using '/dev/dvb/adapter1/frontend0' and '/dev/dvb/adapter1/demux0'
initial transponder DVB-S2 11302750 H 22000000 2/3 AUTO 8PSK
----------------------------------> Using DVB-S2
>>> tune to: 11302:hC23M5S1:S0.0W:22000:
DiSEqC: uncommitted switch pos 0
DiSEqC: switch pos 0, 18V, loband (index 1)
DVB-S IF freq is 1552750
>>> tuning status == 0x00
WARNING: >>> tuning failed!!!
Driver is tbs-linux-drivers_v160126.zip.
What's wrong here?
