LibreELEC (Krypton) v7.90.005 ALPHA
Postby vpeter » Sat Sep 17, 2016 9:50 pm
If anyone still using Matrix for Kodi: http://vpeter.libreelec.tv/imx6-solidru ... r-3.14.tar
Tested with Matrix v1.2 and v2.1.
vpeter
Re: LibreELEC (Krypton) v7.90.005 ALPHA
Postby Cjcr » Sun Sep 18, 2016 6:43 pm
vpeter wrote:If anyone still using Matrix for Kodi: http://vpeter.libreelec.tv/imx6-solidru ... r-3.14.tar
Yeah! we're still using it! :D
Thank you. I will test it later. It works generally well?
Cjcr
Postby buddyrm » Mon Sep 19, 2016 8:43 pm
Yes using it here too. Thanks you again. :-)
buddyrm
Postby ddjpp » Wed Oct 12, 2016 7:06 am
Thanks Peter !!!
ddjpp
Postby buddyrm » Mon Oct 24, 2016 11:06 pm
Well I tried this version on a 1.2 box and although it installs and seems to work, is unable to stream any video. The minute it starts playing any video, it jams. Bunch of garbage on the screen. :-( I tried to reinstall it a few times and can not play any video without it crashing. So this version is not usable with the 1.2 version boxes. Hope there will be one that eventually will work. Thanks anyway. Will have to revert to 6.0. Looks like something going on with the video driver unfortunately in this LibreElec version. :-(
buddyrm
Postby vpeter » Tue Oct 25, 2016 2:29 pm
buddyrm wrote:Hope there will be one that eventually will work.
All this takes time and I don't have it enough for everything. So this will probably not happen in near future.
vpeter
Postby vpeter » Sun Nov 06, 2016 6:48 pm
v7.90.008 in case someone missed ;)
vpeter
Postby sepinho » Tue Mar 14, 2017 9:26 pm
Thank you vpeter, for basically single-handedly keeping the Matrix alive. We as a community owe you alot! Yesterday, I've installed your 7.90.005.1 build on both my Matrix and my Cubox-i. Installation went smoothly and systems are running. But I've noticed that alot of the plugins that I'm trying to use are crashing, plus CEC doesn't seem to work on the Matrix (can't try it on the Cubox-i, because the attached TV doesn't support it). Is that a known issue? Should I try 7.95.1 instead? I'd love to run the same build on both machines.
Anyway, keep up the amazing work, I really, really appreciate it.
sepinho
Postby vpeter » Tue Mar 14, 2017 9:36 pm
I will make 8.0.1 for matrix too when official image will be made (I skipped 8.0.0). It should be ready already some time back but kodi is still at 17.1 rc stage.
vpeter
Postby sepinho » Tue Mar 14, 2017 9:38 pm
So I guess I'll just wait for 8.0.1 and use the addons that work in the meantime. :) Again, thank you for your amazing support!
sepinho
Return to Announcements
