LibreELEC (Krypton) v7.90.008
Re: LibreELEC (Krypton) v7.90.008
Postby vpeter » Sun Nov 20, 2016 11:52 pm
nanasi wrote:
buddyrm wrote:Maybe it is the Version 1.3 Looks like it is waiting for some hardware readiness that never finished. :-(
I suppose that a uninitialized cpu-fuse is the cause for the phenomenon.
I remember the non-unique MAC-address trouble.
Probably not because I have such version without mac address. That's why in this case it is set to 1E:ED:19:27:1A:B2 in u-boot.
vpeter
Postby nanasi » Tue Nov 22, 2016 4:28 am
To check the fuse value, the following uboot command can be used.
If bit1 of fuse value is zero, the security config is not initialized.
Just in case.
TBS-MatrixTV-V1.0.1.1/Profiles/MX6Q\ Linux\ Update/OS\ Firmware/files/u-boot-matrix.imx
U-Boot 2013.04 (Oct 28 2014 - 18:06:53):
Code: Select all
U-boot> imxotp read 4
Fuse at (index: 0x4) value: 0x2
OpenELEC-imx6.arm-6.0.0-matrix/3rdparty/bootloader/u-boot-matrix.imx
U-Boot 2015.10-rc5 (Nov 02 2015 - 19:15:41 +0100):
Code: Select all
Matrix U-Boot> fuse read 0 4
Reading bank 0:
Word 0x00000004: 00000002
nanasi
Postby fdt38 » Sun Dec 25, 2016 12:58 am
vpeter wrote:fdt38, try this version.
Thanks for the link, but I missed your post so I didn't try the file (and now the link fails with Err. 404).
If you can post it again ... (sorry !)
fdt38
Postby Cjcr » Fri Dec 30, 2016 11:55 pm
Hi vpeter,
Are you going to publish LibreElec with the latest version for Matrix? It is very welcome if you do :-D
P.S: Happy new year!
Cjcr
Postby vpeter » Sat Dec 31, 2016 12:09 am
Cjcr wrote:Are you going to publish LibreElec with the latest version for Matrix? It is very welcome if you do :-D
Will do - I just skipped 009 and 010 because there were not much changes.
vpeter
Postby Cjcr » Sat Dec 31, 2016 12:23 am
Oh thank you! ;)
Cjcr
Postby Ahrlad » Mon Jan 02, 2017 11:16 pm
So, my Matrix box boots about one time in five - the rest of the time it ends up with no signal to monitor and no network. I tried to read serial output and it seems it hits some kernel error when it doesn't boot - when it does boot, I can't see any errors in dmesg. I've tried reinstalling LibreElec and trying older and newer versions, with the same results.
I imagine there's some eMMC errors involved. Is there some easy way of making a LibreElec SD card, and some guide on how to get the box to boot from SD?
Ahrlad
Postby Cjcr » Sun Jan 08, 2017 4:29 am
Anyone else is having problems setting up manual IP? it go always to DHCP after restart. There's no way to make it working with fixed IP. It worked fine in OpenElec 6.
Cjcr
Previous
Return to Announcements
