LibreELEC (Krypton) v8.0.2 MR
Postby vpeter » Wed Jun 07, 2017 1:19 am
LibreELEC (Krypton) v8.0.2 MR with Kodi v17.3
Currently can't test it but should work fine.
vpeter
Re: LibreELEC (Krypton) v8.0.2 MR
Postby eraguate » Thu Jun 08, 2017 11:55 am
Thank you once again!
Will test it over the weekend and will let everyone know if I find any issues!
eraguate
Postby franky384 » Sun Jun 18, 2017 3:05 am
You're the best and the only one, it seems, who makes the matrix box usable for me ! Had it thown in the cellar for about a year, now it's back and alive thru your neverending work :!:
franky384
Postby eraguate » Sat Jul 01, 2017 10:03 am
vpeter wrote:LibreELEC (Krypton) v8.0.2 MR with Kodi v17.3
Hi guys,
No luck for me with the last two LibreELEC builds unfortunately. I am using a V2.1 board and despite being able to load the build with the MFGTool I only get a blank screen when trying to boot.
I am reverting to the ancient Android 4.2 build just to verify that the box is still working. It does!
It looks like I am finally ditching the MatrixPC for the RaspberryPI which is easier to update with OSMC...
If anyone knows a way to load a full Linux Distro (debian, arm, etc) on the Matrix please let me know. I would like to give this box a last purpose as a headless Torrent client or FTP server before considering throwing it away.
Thks!
eraguate
Postby vpeter » Sat Jul 01, 2017 1:34 pm
eraguate wrote:No luck for me with the last two LibreELEC builds unfortunately. I am using a V2.1 board and despite being able to load the build with the MFGTool I only get a blank screen when trying to boot.
I also have v2.1.
Can you enable ssh and enable serial console in uEnv.txt file before flashing and after boot check what you get on serial log? And try to connect with ssh (it should work).
Regarding full distro: there are multiple distros available for different devices. It is just a matter of adapting bootloader and device tree. There are recipes how to roll your own image. Not that hard.
vpeter
Postby franky384 » Tue Jul 04, 2017 4:40 pm
I also have a 2.1, i had no problem to install with the mfg tool.
I used the MfgTool2-reinstall.bat.
Try it again
franky384
Postby laruf » Sun Oct 01, 2017 11:19 pm
Hello all,
I've installed this latest release and facing an issue when using my IR remote control. When I press once any button of the remote control, my device take it like I've press twice the same button. I use tu use Openelec, and it works fine. I only face this issue when using Libreelec (any version).
Any idea to help me solve this ?
Regards
Laruf
Matrix v2.1
laruf
Postby laruf » Thu Oct 12, 2017 2:28 pm
Following my last question on the issue, I can see that using CEC remote control mode it works fine.
It seems the issue can be resolved updating /etc/lirc/lircd.conf.xbox file : Need to uncomment this lign "# suppress_repeat 4"
But this file can't be updated. How can it be possible to update this file ?
Thanks in advance for your help
Laruf
Matrix v2.1
laruf
Postby franky384 » Sun Oct 15, 2017 4:36 pm
You have to stop lirc before you edit any lirc config files.
log in via ssh and kill lirc with:
killall lircd
now you can edit the config files, then reboot.
your lircd.conf should be in /storage/.config/lircd.conf
franky384
Postby laruf » Wed Oct 18, 2017 7:51 pm
Hello all
And thanks Franky384 for your help
My problem is solved !
For those who could face the same issue :
copy /etc/lirc/lircd.conf.rpi file to /storage/.config/lircd.conf
And that's it
laruf
Return to Announcements
