Maybe it's a little confusing to speak about MatrixTV 1.0.1.0 in an OpenELEC thread.
Vpeter, we should continue our discussion about IR receiver in MatrixTV 1.0.1.0 thread.
mikebzh44 wrote:Yes, get a V1.3 board.
Which vpeter's patch ?
Did you enter setup ?
Which entry did you setup ?
What are the result of this commands on your box ?
- Code: Select all
[[email protected] ~]# ir-keytable
[[email protected] ~]# for i in /sys/class/input/input* ; do echo -n "$(basename "$i"): "; cat "$i/name"; done
Thanks for your help.
OpenELEC:~ # ir-keytable
Found /sys/class/rc/rc0/ (/dev/input/event2) with:
Driver gpio-rc-recv, table rc-rc6-mce
Supported protocols: NEC RC-5 RC-6 JVC SONY SANYO LIRC other
Enabled protocols: NEC LIRC
Repeat delay = 200 ms, repeat period = 125 msOpenELEC:~ # for i in /sys/class/input/input* ; do echo -n "$(basename "$i"): "; cat "$i/name"; done
input2: gpio_ir_recv
input3: MCE IR Keyboard/Mouse (gpio-rc-recv)Users browsing this forum: No registered users and 1 guest
