Openelec for MatrixTBS
Re: Openelec for MatrixTBS
Postby vpeter » Wed Oct 29, 2014 5:31 pm
franky384 wrote:The green LED is still burning when it states system halted.
Which matrix version (1 or 2)?
vpeter
Postby franky384 » Wed Oct 29, 2014 5:32 pm
Version 2.1
But good news, my USB-Tuner is working again in this version. :P
One question, can i edit anything to make the imx-hdmi-soc,HDMI the default Sounddevice ? My TV is set to poweroff after 3 Hours without useraction, but when i turn it on again Openelec has changed the setting to imx-sgtl5000 Analog every time and makes incredible loud noises when i navigate in XBMC to change back to hdmi. I'm afraid it kills my tv speakers.
I just realized there is no .xbmc symlink to .kodi, therefore the vdr-addon doesn't start. After creating the symlink myself vdr is starting.
franky384
Postby mikebzh44 » Thu Oct 30, 2014 2:08 am
Patch for dual boot is OK with MatrixTV 1.0.1.1 too :D
mikebzh44
Postby vpeter » Thu Oct 30, 2014 2:58 am
franky384:
1.) audio output - will ask experts
2.) .xbmc symlink to .kodi - seems this things needs rework (I note a warning ;) )
3.) green LED on - true. I think the system was completely shut down in the past and need to check older builds.
4.) blue LED is blinking all time - true again. This is my error not rename all xbmc services to kodi services.
Will make one new image in a day or 2.
Update to 1.): select correct audio device in xbmc - imx-hdmi-soc, HDMI as default device. Then should be ok. If not enable debug in xbmc and reproduce the problem. After that put whole log file to pastebin web page or some other sharing site.
vpeter
Postby franky384 » Thu Oct 30, 2014 3:16 am
No need to hurry, all other things work fine, so far !
franky384
Postby vpeter » Thu Oct 30, 2014 3:22 am
franky384, read my last post again for 1.).
vpeter
Postby franky384 » Thu Oct 30, 2014 3:37 pm
vpeter wrote:franky384, read my last post again for 1.).
I have set hdmi as default in system-settings-system-audio, but when my tv powers down and turn it on again the imx-hdmi-soc entry
has changed to Default (imx-spdif Analog) from alone.
franky384
Postby vpeter » Thu Oct 30, 2014 4:13 pm
franky384, seems I can't reproduce that. I turn everything on. All works. Turn TV off. Wait a little. Turn TV on - still everything works.
Can you enable debug mode in xbmc and reboot. When everything is set up turn TV off and then on. Copy xbmc log file and put it somewhere to analyze.
vpeter
Postby franky384 » Thu Oct 30, 2014 5:26 pm
You're right, in the new Openelec build it seems to work fine. It was a issue in the gotham build from 14.09.2014. I booted this build from sdcard to test.
So in the new build it's working o.k. ;)
franky384
Postby vpeter » Thu Oct 30, 2014 5:29 pm
franky384 wrote:So in the new build it's working o.k. ;)
Another checked thing on todo list :lol:
vpeter
PreviousNext
Return to Announcements
