Openelec for MatrixTBS
Re: Openelec for MatrixTBS
Postby piotrasd » Tue Aug 19, 2014 7:59 pm
If somenbody want - here is SABnzbd-Suite addon (couchpotato, sickbeard, headphones) for Openelec Matrix (sabnzbd im not test and maybe dont work)
https://www.sendspace.com/file/vyses7
and here unrar 4.2.4 (compatible with couchpotato auto unrar)
https://www.sendspace.com/file/x9w81n
piotrasd
Postby nwagenaar » Thu Aug 21, 2014 3:59 am
For playback the Matrix with OpenElec seems to do its job almost perfectly (I see the occasional glitch/stutter during playback). But unfortunately (for me) it seems that the dvbhdhomerun plugin isn't working correctly.
Manually running userhdhomerun gives the following error, even after I did the "modprobe dvb_hdhomerun" command : http://pastebin.com/MBCCpuhJ
nwagenaar
Postby vpeter » Thu Aug 21, 2014 2:31 pm
That's probably because we are using so old kernel. Will google it a little if there are any solutions.
Do you see anything useful at the end of dmesg?
vpeter
Postby nwagenaar » Thu Aug 21, 2014 8:21 pm
Unfortunately, not. I put the last dmesg information in the pastebin link I posted earlier.
nwagenaar
Postby AlbertKy » Fri Aug 29, 2014 12:25 pm
I installed Openelec an it works well. But i have a problem with USB-SAT-Box TBS-5990. Dmesg shows me that a device is connected to USB-Port and lsusb shows the device also. But no driver or firmware is loaded. In /lib/firmware/ there are no firmware-files from tbs.
Do i have to install the drivers and firmware from anywhere?
Thanks,
Albert
AlbertKy
Postby vpeter » Fri Aug 29, 2014 2:25 pm
AlbertKy, there is no TBS DVB drivers included because there are no sources and no binaries for me to include.
Few days I'm working on newer kernel 3.14.14 which maybe have better support for this with opensource drivers.
vpeter
Postby AlbertKy » Fri Aug 29, 2014 4:56 pm
Thanks vpeter for your reply.
At my research i have read in a forum, that one is using openelec with this usb-dvb-t-box. But i can't remember where i had read this. With the receiver came a CD with Linux-drivers and Firmwarefiles. Do i have a chance to compile the drivers local? Openelec seems to be a very slim Debian?
Thanks,
Albert.
AlbertKy
Postby vpeter » Fri Aug 29, 2014 5:14 pm
Not sure if anyone runs this tuner with openelec. You can't compile much because their is not anything. If it would I would do that already. With this latest kernel I will see if opensource tbs drivers compile. If not...
Regarding openelc: it is build from scratch with one purpose only - running xbmc.
vpeter
Postby diabloss » Fri Aug 29, 2014 5:20 pm
Only TBS 5980 working by default at the moment
diabloss
Postby AlbertKy » Fri Aug 29, 2014 5:27 pm
Ok, thanks vpeter and diabloss,
then i will be patient and wait for the things that come.
Have a nice Day,
Albert
AlbertKy
PreviousNext
Return to Announcements
