Somehow I managed to get the dvbhdhomerun plugin working on the current OpenElec version for the Matrix device. However, I found out that TVHeadend version is quite old and it's missing quite a lot of interesting features that should make our lives easier (for example, the local channel number option is missing in the original version). So I build my own binary based upon the latest 3.9 GIT and made it available for others to use.
Before replacing your TVHeadend, please be aware of the following:
- Since the TVHeadend 3.9 editions use a new config format, it means you need to start over again or convert the current version first (see https://tvheadend.org/boards/5/topics/9792).
- This build are provided as is, is not optimized in any way and using it is at your own risk. I can't be held responsible for any issues that may arise like bricked or unstable devices. They seemed to work fine on my device, but this doesn't mean it'll work for you.
Just unpack it, backup the current tvheadend binary and configuration, overwrite the binary with the new version and do a chmod a+x on the binary. Reboot your device and my version should be active.
In case anybody wants to use it, you can grab it from here: http://shalafi.home.xs4all.nl/moi/20143 ... rix.tar.gz
