Openelec for MatrixTBS
Re: Openelec for MatrixTBS
Postby franky384 » Mon Sep 15, 2014 4:32 pm
Just installed the new version and it works o.o.t.b. with my mystique/dvbsky S960 USB-Tuner:
[ 7.273533] usb 1-1.4: dvb_usb_v2: found a 'DVBSky S960/S860' in warm state
[ 7.278091] usb 1-1.4: dvb_usb_v2: will pass the complete MPEG2 transport stream to the software demuxer
[ 7.278332] DVB: registering new adapter (DVBSky S960/S860)
[ 7.280394] dvbsky_usb MAC address=00:17:42:54:96:0c
[ 7.280420] usb 1-1.4: dvb_usb_v2: MAC address: 00:17:42:54:96:0c
[ 7.403092] Chip Version Info: CHIP_8188E_Normal_Chip_TSMC_D_CUT_1T1R_RomVer(0)
[ 7.432722] DS3000 chip version: d0 attached.
[ 7.434021] TS202x chip version[1]: c1 attached.
[ 7.443271] TS202x chip version[2]: c3 attached.
[ 7.465917] usbcore: registered new interface driver r8188eu
[ 7.496567] dvbsky_m88ds3103_load_firmware: Waiting for firmware upload (dvb-fe-ds3103.fw)...
[ 7.503287] dvbsky_m88ds3103_load_firmware: Waiting for firmware upload(2)...
[ 7.559877] systemd-journald[230]: Received request to flush runtime journal from PID 1
[ 7.903089] input: eventlircd as /devices/virtual/input/input7
[ 8.176434] fec 2188000.ethernet eth0: Freescale FEC PHY driver [Generic PHY] (mii_bus:phy_addr=2188000.ethernet:04, irq=-1)
[ 8.176629] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 8.660662] usb 1-1.4: DVB: registering adapter 0 frontend 0 (Montage DS3103/TS2022)...
[ 8.665371] Registered IR keymap rc-dvbsky
[ 8.665739] input: DVBSky S960/S860 as /devices/soc0/soc.1/2100000.aips-bus/2184200.usb/ci_hdrc.1/usb1/1-1/1-1.4/rc/rc1/input9
[ 8.666012] rc1: DVBSky S960/S860 as /devices/soc0/soc.1/2100000.aips-bus/2184200.usb/ci_hdrc.1/usb1/1-1/1-1.4/rc/rc1
[ 8.666031] usb 1-1.4: dvb_usb_v2: schedule remote query interval to 300 msecs
[ 8.666044] usb 1-1.4: dvb_usb_v2: 'DVBSky S960/S860' successfully initialized and connected
[ 8.666159] usbcore: registered new interface driver dvb_usb_dvbsky
[ 12.189013] libphy: 2188000.ethernet:04 - Link is Up - 1000/Full
[ 12.189044] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
THANKS FOR YOUR GREAT WORK !!
franky384
Postby vpeter » Mon Sep 15, 2014 5:07 pm
franky384 wrote:Just installed the new version and it works o.o.t.b. with my mystique/dvbsky S960 USB-Tuner
This was the reason why I moved to some up to date kernel version. I'm glad it works 8-)
vpeter
Postby franky384 » Mon Sep 15, 2014 5:10 pm
What sources are you using?
I'll try to compile the vdr-sc-addon, on my Raspberry Pi i was able to make it work.
franky384
Postby vpeter » Mon Sep 15, 2014 5:29 pm
franky384 wrote:What sources are you using?
Unpublished iMX6 project (but will be public soon). But you can use Cuboxi project to compile addon.
And let me know if you succeed and how because friend is interested in this also.
vpeter
Postby franky384 » Tue Sep 16, 2014 1:26 am
Ok, i will try and report, friend ;)
franky384
Postby Cjcr » Tue Sep 16, 2014 2:25 am
vpeter wrote:Gotham with shutdown and spdif: http://l.bitcasa.com/wU2Kid3S
Works with my equipment.
Helix is not updated. If someone wants that let me know.
Hi vpeter,
I'm using the first OpenElec release that you published here, which have the kernel 3.0.35-2666-gbdde708 and it works well ... not perfect, but well.
This one I quoted have a most recent kernel version? how it works? better than before?
Cjcr
Postby franky384 » Tue Sep 16, 2014 2:56 am
This one uses kernel 3.14.18, work's very good for me as i wrote here viewtopic.php?f=155&t=8859&p=31860#p31853
franky384
Postby vpeter » Tue Sep 16, 2014 3:02 am
I would go with latest one because it can be improved. The first release based on old kernel will never be updated.
vpeter
Postby Cjcr » Tue Sep 16, 2014 3:29 am
vpeter wrote:I would go with latest one because it can be improved. The first release based on old kernel will never be updated.
That's great! There's any thing that worked before (old kernel) that doesn't work now?
Cjcr
Postby stevie101 » Tue Sep 16, 2014 12:58 pm
@vpeter,
which branch in your rep do I need to checkout - I see that matrix2 / matrix3 are missing the Matrix project folder.
The only issue I have with 3.0.35 is slight video stuttering randomly (also with 13.2), so I would like to try 3.1x.
Thanks.
stevie101
PreviousNext
Return to Announcements
