To burn the images
For v1.3 use the v1 reinstall.bat script , for v2.1 use reinstall v2.1.bat
Don't run exe - run bat.
To burn the images
vpeter wrote:Sillyname, not sure what is wrong. Did you set the small switch to correct position? Which Matrix hw version are you using? Which bat file did you run?
Yes. I compare the log with mine and it's very similar to yours. It should be ok.Sillyname wrote:Did you receive the PM?
Then I don't know why Openelec doesn't. If you would have serial console attached maybe you would see something from there. But without that ... it's almost impossible to tell.Sillyname wrote:MatrixTV works...
