OpenELEC Beta 4.95.1
Re: OpenELEC Beta 4.95.1
Postby PeterB » Sat Nov 08, 2014 3:24 am
vpeter wrote:Now I see the problem. Funny thing ;) It paints only some part of the screen because algorithmdirtyregions is set to 1 (Union) in advancedsettings.xml to minimize cpu usage. If set to 3 (Whole Screen) then whole screen is repainted.
That does the trick ... fixed.
On Gotham I had different issue I think.
That may be so, but the symptoms were identical.
BTW, I've had to re-create my autostart.sh with the sleep command, in order to have reliable access to the remote sql database.
PeterB
Postby barhom » Sat Nov 08, 2014 2:48 pm
What do you use exactly to flash the tbs2910 with OpenELEC-imx6.arm-4.95.1.tar ?
Would be great if you included a installation guide.
Thanks,
barhom
Postby vpeter » Sat Nov 08, 2014 3:49 pm
barhom wrote:What do you use exactly to flash the tbs2910 with OpenELEC-imx6.arm-4.95.1.tar ?
Inside MY archive not official one you have a folder called TBS-Matrix-MfgTool2. Inside just click MfgTool2-reinstall.bat to completely reinstall openelec on a device. Or click MfgTool2-update.bat to just update the system and you settings remain. Of couse you can also update running openelec with putting tar achieve into Update folder on samba share.
vpeter
Postby PeterB » Sat Nov 08, 2014 7:56 pm
I have a mechanism that allows the firmware to be flashed natively on the TBS2910, without use of MfgTool (which only runs on a Windows box).
I have documented the first two stages of the process within the earlier OpenELEC thread. I will document the third (final) stage, and pull this together with the previous two postings.
PeterB
Postby diabloss » Tue Nov 11, 2014 5:47 pm
There is allready beta 2 of Kodi , think Peter will have in the weekend a newer build based on kodi beta 2
diabloss
Postby piotrasd » Tue Nov 11, 2014 10:18 pm
any chance to get worked PCIE in next version ?
piotrasd
Postby vpeter » Wed Nov 12, 2014 4:35 am
piotrasd wrote:any chance to get worked PCIE in next version ?
No, because I don't have any card to actually test this functionality. When I find one card to borrow from a friends or someone else then I will continue with this remaining hw issue on tbs matrix.
Btw: RTC is already working too on v2 hw.
vpeter
Postby vpeter » Mon Nov 17, 2014 3:31 pm
vpeter
Previous
Return to Announcements
