OpenELEC Beta 4.95.2 and more
Re: OpenELEC Beta 4.95.2
Postby Hekser » Wed Nov 26, 2014 12:38 am
Using OpenELEC-imx6.arm-4.95.3. Try to mount remote windows smb share.
mount -t cifs -o username=user,password=pass //192.168.2.2/d/video /storage/videos/
Ok.
But it used smb1, and transfer speed is too low(about 10mb/s). How can i force to use smb2 protocol?
Hekser
Postby vpeter » Wed Nov 26, 2014 1:55 am
Hekser wrote:But it used smb1, and transfer speed is too low(about 10mb/s). How can i force to use smb2 protocol?
No idea. Check wiki. Also try mouting in kodi itself not from command line. Wireless or wired connection?
vpeter
Postby Hekser » Wed Nov 26, 2014 2:30 am
wired. 1Gbs
One more try:
Code: Select all
mount -t cifs -o username=user,password=pass,vers=2 //192.168.2.2/d/video /storage/videos/
mount: mounting //192.168.2.2/d/video on /storage/videos/ failed: Invalid argument
vpeter wrote:Also try mouting in kodi itself not from command line.
And how is the speed?
Hekser
Postby Hekser » Wed Nov 26, 2014 4:36 am
another experiments, using kodi to access the files:
proto speed
smb ~5-10mbs
ftp ~5-10mbs
nfs ~10mbs
So, video-files, larger than 4Gb, are unplayable
The best result: download file over ftp to ramdisk on TBS(20-30mbs).
Update:
iperf results
Code: Select all
OpenELEC:~ # iperf -c 192.168.2.15 -d
Server listening on TCP port 5001
TCP window size: 85.3 KByte (default)
Client connecting to 192.168.2.15, TCP port 5001
TCP window size: 43.8 KByte (default)
[  5] local 192.168.2.91 port 53562 connected with 192.168.2.15 port 5001
[  4] local 192.168.2.91 port 5001 connected with 192.168.2.15 port 25818
[ ID] Interval       Transfer     Bandwidth
[  5]  0.0-10.0 sec   366 MBytes   307 Mbits/sec
[  4]  0.0-13.7 sec  1.12 MBytes   690 Kbits/sec
Hekser
Postby Ahrlad » Mon Dec 01, 2014 5:34 am
Thanks!
I got it working at last with one of the older versions, though one of the programs required a symbolic link from "/storage/.kodi" :)
If anyone else is interested in a download/seedbox, check out https://github.com/lsellens/ Or add repo from zipfile: http://repository-lsellens.googlecode.c ... ellens.zip
Ahrlad
Postby Ahrlad » Mon Dec 01, 2014 5:43 am
I was wondering about setting up my matrix as a small RAID5 server with three sata hdds... has anyone had any experience with mpcie to sata controller cards such as http://www.conrad.com/ce/en/product/1195021/SATA-III-2PORT-MINI-PCIE-KARTE?ref=list/ ?
I can't read from the web page if linux drivers even exist. What are the chances of the card working in openelec? Does Matrix openelec have any pcie support outside of dtv cards?
Ahrlad
Postby vpeter » Mon Dec 01, 2014 3:32 pm
Ahrlad, forget raid support on openelec. Use "normal" distro for this.
vpeter
Postby Ahrlad » Mon Dec 01, 2014 5:09 pm
All right, all right, I will. But it would be so very cool :)
Ahrlad
Postby antonl1911 » Wed Dec 03, 2014 4:21 pm
Update to 4.97 brokes this build. Beware!
antonl1911
Postby Hekser » Thu Dec 04, 2014 4:25 pm
antonl1911 wrote:Update to 4.97 brokes this build. Beware!
Where did you get the 4.97 release for TBS2910?
Hekser
PreviousNext
Return to Announcements
Users browsing this forum: Bing [Bot] and 1 guest
