OpenELEC Beta 4.95.2 and more
Re: OpenELEC Beta 4.95.2 and more
Postby MikeDotBe » Mon Feb 23, 2015 6:18 pm
ok i'll try this evening...
Thanks for all your help
Mike
ps : dou you think that running the update from a windows xp (without UAC) may solve the problem?
MikeDotBe
Postby vpeter » Tue Feb 24, 2015 12:57 am
MikeDotBe Wrote:running the update from a windows xp (without UAC) may solve the problem?
Don't know because I'm Administrator on all my Windows machines.
vpeter
Postby MikeDotBe » Tue Feb 24, 2015 7:10 am
I'm also admin on my computers...
but does not seems to run as admin ...
Tryed the replacement of the cfg.ini content : does not work...
tryed under windows xp : does not work either...
here is the log file under windows xp
DLL version: 2.2.3
Tuesday, February 24, 2015 00:03:57   Start new logging
ModuleID[2] LevelID[10]: CMyExceptionHandler thread is running
ModuleID[2] LevelID[1]: new MxHidDeviceClass
ModuleID[2] LevelID[1]: *** Error: 1, Drive: A:
ModuleID[2] LevelID[10]: DeviceTypeDisk--_devices size: 1
ModuleID[2] LevelID[10]: Volume--StorageDisk, Disk->_driveNumber:1, Volume->_diskNumber:1
ModuleID[2] LevelID[10]: DeviceTypeDisk--find Disk device: 00B4DB68
ModuleID[2] LevelID[10]: Device::hubIndex::getmsc, return the port index is: 1
ModuleID[2] LevelID[10]: Device Manager thread is running
ModuleID[2] LevelID[10]: CmdOperation[0] device chagned and reset to state 1
ModuleID[2] LevelID[10]: ExecuteCommand--Push[WndIndex:0], Body is $ echo 0 > /sys/block/mmcblk0boot0/force_ro
ModuleID[2] LevelID[10]: ExecuteCommand--Push[WndIndex:0], Body is send
ModuleID[2] LevelID[10]: ExecuteCommand--Push[WndIndex:0], Body is $ dd if=$FILE of=/dev/mmcblk0boot0 bs=1024 seek=1
ModuleID[2] LevelID[10]: ExecuteCommand--Push[WndIndex:0], Body is $ echo 1 > /sys/block/mmcblk0boot0/force_ro
ModuleID[2] LevelID[10]: ExecuteCommand--Push[WndIndex:0], Body is $ echo 8 > /sys/devices/platform/sdhci-esdhc-imx.3/mmc_host/mmc0/mmc0:0001/boot_config
ModuleID[2] LevelID[10]: ExecuteCommand--Push[WndIndex:0], Body is pipe dd of=partitition-emmc.sh
ModuleID[2] LevelID[10]: ExecuteCommand--Push[WndIndex:0], Body is frf
ModuleID[2] LevelID[10]: ExecuteCommand--Push[WndIndex:0], Body is $ sh partitition-emmc.sh /dev/mmcblk0
ModuleID[2] LevelID[1]: PortMgrDlg(0)--MSCDevice--Command Push(no file) excute failed
ModuleID[2] LevelID[10]: CmdOperation[0], current command executed failed, so SetEvent(hDevCanDeleteEvent)
ModuleID[2] LevelID[10]: CCmdOpreation[0] thread is Closed
ModuleID[2] LevelID[10]: DeviceManager::OnMsgDeviceEvent() - EVENT_KILL
ModuleID[2] LevelID[10]: CMyExceptionHandler::OnMsgExceptionEvent() - KillExceptionHandlerThread
ModuleID[2] LevelID[10]: Exception Handler thread is closed
ModuleID[2] LevelID[1]: delete MxHidDeviceClass
ModuleID[2] LevelID[10]: Device Manager thread is closed
and the one from windows 8
DLL version: 2.2.3
Tuesday, February 24, 2015 00:07:49   Start new logging
ModuleID[2] LevelID[10]: new MxHidDevice[02D09D18]
ModuleID[2] LevelID[10]: CmdOperation[0] device chagned and reset to state 0
ModuleID[2] LevelID[10]: ExecuteCommand--Boot[WndIndex:0], File is C:\Users\Mike\Desktop\MatrixTV\OpenELEC-imx6.arm-5.0.0\MfgTool2-TBS-Matrix\Profiles\MX6Q Linux Update\OS Firmware\mfgtool2\u-boot-mx6q-sabresd.bin
ModuleID[2] LevelID[10]: ExecuteCommand--Load[WndIndex:0], File is C:\Users\Mike\Desktop\MatrixTV\OpenELEC-imx6.arm-5.0.0\MfgTool2-TBS-Matrix\Profiles\MX6Q Linux Update\OS Firmware\mfgtool2\uImage, address is 0x10800000
ModuleID[2] LevelID[10]: PortMgrDlg(0)--Command Load excute successfully, retry count: 0
ModuleID[2] LevelID[10]: ExecuteCommand--Load[WndIndex:0], File is C:\Users\Mike\Desktop\MatrixTV\OpenELEC-imx6.arm-5.0.0\MfgTool2-TBS-Matrix\Profiles\MX6Q Linux Update\OS Firmware\mfgtool2\initramfs.cpio.gz.uboot, address is 0x10C00000
ModuleID[2] LevelID[10]: ExecuteCommand--Jump[WndIndex:0]
ModuleID[2] LevelID[10]: *********MxHidDevice[02D09D18] Jump to Ramkernel successfully!**********
ModuleID[2] LevelID[10]: CmdOperation[0], current state command has been finished and the last command is successful, so SetEvent(hDevCanDeleteEvent)
ModuleID[2] LevelID[10]: DeviceManager::DevChangeWnd::OnDeviceChange() - DEVICE_REMOVAL_EVT(\\?\USB#VID_15A2&PID_0054#6&23286a80&0&5#{a5dcbf10-6530-11d2-901f-00c04fb951ed})
ModuleID[2] LevelID[10]: DeviceManager::DevChangeWnd::OnDeviceChange() - end
ModuleID[2] LevelID[10]: DeviceManager::OnMsgDeviceEvent() - DEVICE_REMOVAL_EVT(\\?\USB#VID_15A2&PID_0054#6&23286a80&0&5#{a5dcbf10-6530-11d2-901f-00c04fb951ed})
ModuleID[2] LevelID[10]: DeviceClass::FindDeviceByUsbPath--DeviceListType_Current, _devices.size: 1
ModuleID[2] LevelID[10]: DeviceClass::FindDeviceByUsbPath--DeviceListType_Current, devInstPathToFind: USB\VID_15A2&PID_0054\6&23286A80&0&5, _deviceInstanceID: USB\VID_15A2&PID_0054\6&23286A80&0&5
ModuleID[2] LevelID[10]: DeviceClass::FindDeviceByUsbPath--DeviceListType_Current, Find the device
ModuleID[2] LevelID[10]: DeviceManager::OnMsgDeviceEvent() - DEVICE_REMOVAL_EVT,[MxHidDeviceClass] vid_15a2&pid_0054, Hub:3-Port:5
ModuleID[2] LevelID[10]: DeviceManager::OnMsgDeviceEvent() - DEVICE_REMOVAL_EVT, Notify
ModuleID[2] LevelID[10]: CmdOpreation[0]--OnDeviceChangeNotify, Volume Arrive/Remove or Device Arrive/Remove
ModuleID[2] LevelID[10]: CmdOpreation[0]--OnDeviceChangeNotify, m_p_usb_port is not NULL, so only refresh
ModuleID[2] LevelID[10]: CmdOpreation[0]--OnDeviceChangeNotify, Volume/Device Remove
ModuleID[2] LevelID[1]: CmdOpreation[0]--set m_hDeviceRemoveEvent.
ModuleID[2] LevelID[10]: CmdOpreation[0]--WaitforEvents device remove1
ModuleID[2] LevelID[10]: DeviceManager::OnMsgDeviceEvent()-DEVICE_REMOVAL_EVT, hDevCanDeleteEvent has been set
ModuleID[2] LevelID[10]: delete MxHidDevice[02D09D18]
ModuleID[2] LevelID[10]: DeviceManager::DevChangeWnd::OnDeviceChange() - DEVICE_ARRIVAL_EVT(\\?\USB#VID_066F&PID_37FF#6&23286a80&0&5#{a5dcbf10-6530-11d2-901f-00c04fb951ed})
ModuleID[2] LevelID[10]: DeviceManager::OnMsgDeviceEvent() - DEVICE_ARRIVAL_EVT(\\?\USB#VID_066F&PID_37FF#6&23286a80&0&5#{a5dcbf10-6530-11d2-901f-00c04fb951ed})
ModuleID[2] LevelID[10]: DeviceManager::OnMsgDeviceEvent() - DEVICE_ARRIVAL_EVT,[Msc,DiskDeviceClass] vid_066f&pid_37ff, not handled
ModuleID[2] LevelID[10]: DeviceManager::DevChangeWnd::OnDeviceChange() - VOLUME_ARRIVAL_EVT(D)
ModuleID[2] LevelID[10]: DeviceManager::OnMsgDeviceEvent() - VOLUME_ARRIVAL_EVT(D)
ModuleID[2] LevelID[10]: VolumeDeviceClass::AddUsbDevice()  D
ModuleID[2] LevelID[10]: DeviceTypeDisk--find Disk device: 02D09CE0
ModuleID[2] LevelID[10]: Device::hubIndex::getmsc, return the port index is: 5
ModuleID[2] LevelID[10]: VolumeDeviceClass::AddUsbDevice() successful D add to current list, retrycount: 0
ModuleID[2] LevelID[10]: DeviceManager::OnMsgDeviceEvent() - VOLUME_ARRIVAL_EVT-Disk(D), Hub:3-Port:5
ModuleID[2] LevelID[10]: DeviceManager::OnMsgDeviceEvent() - VOLUME_ARRIVAL_EVT, Notify
ModuleID[2] LevelID[10]: CmdOpreation[0]--OnDeviceChangeNotify, Volume/Device Arrive
ModuleID[2] LevelID[1]: CmdOpreation[0]--set m_hDeviceArriveEvent.
ModuleID[2] LevelID[10]: CmdOpreation[0]--WaitforEvents device arrive1
MikeDotBe
Postby MikeDotBe » Tue Feb 24, 2015 7:30 am
i've also been (finally) able to launch the bat file as admin (using the full path to mfgtools2.exe in the bat file) and it does not work.
MikeDotBe
Postby vpeter » Tue Feb 24, 2015 3:25 pm
Sadly I can't help you more because I'm out of ideas. For me it always worked. If not it was because of some file missing or some other error. With this error
I'm not familiar with.
vpeter
Postby MikeDotBe » Tue Feb 24, 2015 8:58 pm
Maybe the device is broken....
but if it install v1.0.1.1 i assume that it's not broken...
WHat is the reason uf the Bat file?
why does not the MFGTools2.exe work in standalone?
MikeDotBe
Postby vpeter » Tue Feb 24, 2015 9:36 pm
MikeDotBe Wrote:Maybe the device is broken....
Device doesn't seems to be broken if matrixtv works.
Reason for bat file is to have different load options. One is compete reinstall, then there is only to update bootloader or it's configuration, only to update. There is nothing wrong with this approach. And I also give you option to run mfgtool2 directly with different init file and it didn't help.
vpeter
Postby Dinos52 » Tue Feb 24, 2015 11:14 pm
@MikeDotBe:
Sorry for interfering, but did you ever try it on another PC or maybe with a virtual machine with a clean OS?
Dinos52
Postby vpeter » Wed Feb 25, 2015 2:11 am
MikeDotBe, try this image: OpenELEC-imx6.arm-5.0.0-TBS-Matrix-test1.tar
You can run MfgTool2.exe directly. If this doesn't work.... then I'm really out of ideas.
vpeter
Postby vpeter » Wed Feb 25, 2015 5:16 pm
Another hint can be this: When MfgTool reports an error stop and close it but leave the board running. Open a new instance of MfgTool and flash again. Maybe the process will succeed.
vpeter
PreviousNext
Return to Announcements
Users browsing this forum: No registered users and 13 guests
