Dinos52 wrote:No, it's definitely not an iMX6 issue! Once again: OpenELEC Gotham 13.2 is ok on the Matrix!
Then tell me what is the difference between TBS Matrix, Udoo and Cubox-i? Almost nothing. Your issues should happen on all systems and not just matrix. And did you reported this issues on Kodi github or anything else? Probably not. And you expect solution? Good one
And do you remember the deinterlace issues you had if I'm not mistaken? Helix can work just the same as Gotham - just need correct setup.
Dinos52 wrote:I do not know your age
My age is enough to understand things. Telling someone who is doing only integration work about some specific bugs has nothing to do with age.
Anyway, I'm done with arguing. If I made any more image I don't want any more feedback for bugs which are clearly kodi/imx6 related. I don't have knowledge to fix them.
