OpenELEC Beta 4.95.2 and more
Re: OpenELEC Beta 4.95.2
Postby LSD » Fri Dec 05, 2014 6:30 pm
yeah I know that delaying the start would fix it, but also a network that's available faster would do the trick, which I would see as the prefered fix :-), but thanks anyway.
LSD
Postby vpeter » Fri Dec 05, 2014 8:47 pm
LSD wrote:There is a general problem with pci-e or just the lack of HW for you to try it out?
I only have this adapter: https://shop.tbsdtv.com/pm2c-pcie-mini-pc ... ml?cPath=9
But I don't know if this actually works. I tried to enable some things in kernel config for pcie but I haven't seen any device on PCI bus (was testing with one network card only). I also applied external power to this adapter from main matrix board and still nothing. That's why I just gave up until it's clear how it should work.
vpeter
Postby LSD » Fri Dec 05, 2014 9:27 pm
ok, I see, I just built with PCI_IMX6 and a bunch of other stuff enabled in my config and have to wait till I get home and have time to test it. Stay tuned
LSD
LSD
Postby LSD » Fri Dec 05, 2014 11:09 pm
Mini-PCIe IS WORKING :-)
[ 6.700836] ieee80211 phy0: Atheros AR9300 Rev:3 mem=0xf0c80000, irq=155
and I have WLAN1 Interface in ifconfig, and AP-mode is working, so now I have something to play with
LSD
LSD
Postby vpeter » Sat Dec 06, 2014 12:50 am
LSD wrote:Mini-PCIe IS WORKING
Great! Can you send me what you enabled in kernel for this and it will be included once it will be merged to official repository. I just hope there will be no problems with other systems using same build (cubox-i and soon also udoo).
vpeter
Postby LSD » Sat Dec 06, 2014 3:50 am
basically it should be just a matter of
CONFIG_PCI=y
CONFIG_SOC_IMX6Q=y
CONFIG_PCI_IMX6=y
CONFIG_PCIEPORTBUS=y
CONFIG_PCIE_DW=n
I did just add my Ath9K driver and some regional settings tweaking (as my card's eeprom is in world domain 0 and this is the easiest way to override this, but I don't know yet if these settings are supported in kernel 3.14 as I have no idea how to tell connmanager to tethter on 5GHz yet). During build when it compiled the kernel, it did ask for a lot of settings which seemed not to be in the config yet which I accespted all with defaults by now. So there is still some work to do to figure out if defaults are ok and which drivers should be included as well. It should not break cubix-i build but if you want to make sure the kernel config should depend on the target device.
Also I still have my slow network setup / 100mbit problem which needs further Investigation, but next I will ask on OE Forum if they can help me configuring 5GHz.
LSD
Postby Hekser » Sun Dec 07, 2014 7:20 am
Do you have any ideas what i can do with a visualizer bug? (viewtopic.php?f=155&t=9225&start=20#p32633)
Maybe it is part of some audio bug?
Hekser
Postby PeterB » Sun Dec 07, 2014 11:34 am
LSD wrote:Also I still have my slow network setup / 100mbit problem which needs further Investigation
There is definitely something odd about your system. Here is some info from one of my Matrix boxes running OE 4.95.3:
Code: Select all
[    6.695369] Chip Version Info: CHIP_8188E_Normal_Chip_TSMC_D_CUT_1T1R_RomVer(0)
[    6.731035] usbcore: registered new interface driver r8188eu
[    7.263517] fec 2188000.ethernet eth0: Freescale FEC PHY driver [Generic PHY] (mii_bus:phy_addr=2188000.ethernet:04, irq=-1)
[    7.263711] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   11.276169] libphy: 2188000.ethernet:04 - Link is Up - 1000/Full
[   11.276215] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
and:
Code: Select all
Matrix2:~ # ethtool eth0
Settings for eth0:
   Supported ports: [ TP MII ]
   Supported link modes:   10baseT/Half 10baseT/Full
                           100baseT/Half 100baseT/Full
                           1000baseT/Full
   Supported pause frame use: Symmetric
   Supports auto-negotiation: Yes
   Advertised link modes:  10baseT/Half 10baseT/Full
                           1000baseT/Full
   Advertised pause frame use: Symmetric
   Advertised auto-negotiation: Yes
   Link partner advertised link modes:  10baseT/Half 10baseT/Full
                                        1000baseT/Full
   Link partner advertised pause frame use: Symmetric
   Link partner advertised auto-negotiation: Yes
   Speed: 1000Mb/s
   Duplex: Full
   Port: MII
   PHYAD: 4
   Transceiver: external
   Auto-negotiation: on
   Link detected: yes
PeterB
Postby LSD » Sun Dec 07, 2014 5:58 pm
yes, I do have revision 2.3, found not much, or lets better say nothing about this revision by now. After trying to test with a original TBS build my eMMC seems to have died (don't know yet if it's just an u-boot problem or if it's really broken, have opened a thread and waiting for a reply). As Rev 2.3 has only 4 dip switches I also do have no idea how to make it boot from SD, so currently I just can wait :evil:
LSD
Postby Hekser » Sun Dec 07, 2014 11:21 pm
I've got some error logs... Full : http://pastebin.com/QN8b4QVC
Code: Select all
18:12:23 T:1968324608   DEBUG: SECTION:LoadDLL(special://xbmcbin/system/ImageLib-arm.so)
18:12:23 T:1968324608   DEBUG: Loading: /usr/lib/kodi/system/ImageLib-arm.so
18:12:23 T:1958736960    INFO: CAESinkALSA - ALSA: /home/uroot/OpenELEC.tv/build.OpenELEC-imx6.arm-devel/alsa-lib-1.0.28/src/confmisc.c:768:(parse_card) cannot find card '$CARD'
18:12:23 T:1958736960    INFO: CAESinkALSA - ALSA: /home/uroot/OpenELEC.tv/build.OpenELEC-imx6.arm-devel/alsa-lib-1.0.28/src/conf.c:4259:(_snd_config_evaluate) function snd_func_card_driver returned error: No such device
18:12:23 T:1958736960    INFO: CAESinkALSA - ALSA: /home/uroot/OpenELEC.tv/build.OpenELEC-imx6.arm-devel/alsa-lib-1.0.28/src/confmisc.c:392:(snd_func_concat) error evaluating strings
18:12:23 T:1958736960    INFO: CAESinkALSA - ALSA: /home/uroot/OpenELEC.tv/build.OpenELEC-imx6.arm-devel/alsa-lib-1.0.28/src/conf.c:4259:(_snd_config_evaluate) function snd_func_concat returned error: No such device
18:12:23 T:1958736960    INFO: CAESinkALSA - ALSA: /home/uroot/OpenELEC.tv/build.OpenELEC-imx6.arm-devel/alsa-lib-1.0.28/src/confmisc.c:1251:(snd_func_refer) error evaluating name
18:12:23 T:1958736960    INFO: CAESinkALSA - ALSA: /home/uroot/OpenELEC.tv/build.OpenELEC-imx6.arm-devel/alsa-lib-1.0.28/src/conf.c:4259:(_snd_config_evaluate) function snd_func_refer returned error: No such device
18:12:23 T:1958736960    INFO: CAESinkALSA - ALSA: /home/uroot/OpenELEC.tv/build.OpenELEC-imx6.arm-devel/alsa-lib-1.0.28/src/conf.c:4738:(snd_config_expand) Evaluate error: No such device
18:12:23 T:1958736960    INFO: CAESinkALSA - ALSA: /home/uroot/OpenELEC.tv/build.OpenELEC-imx6.arm-devel/alsa-lib-1.0.28/src/confmisc.c:1286:(snd_func_refer) Unable to find definition 'cards.imx-hdmi-soc.pcm.iec958.0:CARD=0,AES0=4,AES1=130,AES2=0,AES3=2'
18:12:23 T:1958736960    INFO: CAESinkALSA - ALSA: /home/uroot/OpenELEC.tv/build.OpenELEC-imx6.arm-devel/alsa-lib-1.0.28/src/conf.c:4259:(_snd_config_evaluate) function snd_func_refer returned error: No such file or directory
18:12:23 T:1958736960    INFO: CAESinkALSA - ALSA: /home/uroot/OpenELEC.tv/build.OpenELEC-imx6.arm-devel/alsa-lib-1.0.28/src/conf.c:4738:(snd_config_expand) Evaluate error: No such file or directory
18:12:23 T:1958736960    INFO: CAESinkALSA - ALSA: /home/uroot/OpenELEC.tv/build.OpenELEC-imx6.arm-devel/alsa-lib-1.0.28/src/conf.c:4705:(snd_config_expand) Unknown parameters CARD=imxhdmisoc,DEV=0
18:12:23 T:1958736960    INFO: CAESinkALSA - ALSA: /home/uroot/OpenELEC.tv/build.OpenELEC-imx6.arm-devel/alsa-lib-1.0.28/src/conf.c:4589:(parse_args) Unknown parameter DEV
18:12:23 T:1958736960    INFO: CAESinkALSA - ALSA: /home/uroot/OpenELEC.tv/build.OpenELEC-imx6.arm-devel/alsa-lib-1.0.28/src/conf.c:4722:(snd_config_expand) Parse arguments error: No such file or directory
18:12:23 T:1958736960    INFO: CAESinkALSA - ALSA: /home/uroot/OpenELEC.tv/build.OpenELEC-imx6.arm-devel/alsa-lib-1.0.28/src/confmisc.c:1286:(snd_func_refer) Unable to find definition 'cards.imx-hdmi-soc.pcm.iec958.0:CARD=imxhdmisoc,AES0=4,AES1=130,AES2=0,AES3=2'
Hekser
PreviousNext
Return to Announcements
Users browsing this forum: Bing [Bot] and 1 guest
