Hi all,
I hoped that this would be OK even for V.1.3 Hardware but it isn't. Using MfG Tool - stops in the middle.
So i used the old V12.04 V1.0.0.1 tool tree as a basic, exchanged the files rootfs.tar.bz2 to the new one with rootfs.tar.gz, uboot-moipro.* , uImage as well and mksdcard.sh... and modified the XML file to make this work.
I see in the serial log, that now the damned VFAT partition is gone now: Somebody has listen to me? Great.
But here it comes: MfG tool could not finish extraction
<CMD state="Updater" type="push" body="pipe tar -zxv -C /mnt/mmcblk0p1" file="files/rootfs.tar.gz">Sending and writting rootfs</CMD>
because:
var/cache/apt-xapian-index/index.3/synonym.DB
var/cache/apt-xapian-index/index.3/postlist.DB
var/cache/apt-xapian-index/index.3/spelling.DB
tar: short read
MfG tool Error-message:
"Push" error, file="D:\MATRIXTV\TBS-Matrix-Ubuntu_12.04_V1.0.0.1-V2mod\Profiles\MX6Q Linux Update\OS Firmware\files\rootfs.tar.gz"
Can somebody fix this please and please check this and maybe change uboot to a version, the old hardware V.12/3 can handle?
The uboot moipro version should be related to the HW v.21 ? Or is it fitting to both versions?
So I guess this is another try and error release
which wasn't finally tested and deployed to steal customers time.
