The V1.3 Have ddr3 ram and the V2.1 have ddr3L Ram
Is ist possible that the 1.3 is undervolted
And have you your own uboot and kernel config
I have build one from Openelec git and i saw there are different
babboy wrote:today i got a second Matrix 1.3 and it works
but my 1.3 not, it Freezes after boot before the wizard starts
[ 40.079296] BUG: soft lockup - CPU#3 stuck for 23s! [kworker/3:1:92] APPLY PATCH (common - arm) /home/babboy/Openelec/Matrix/packages/tools/u-boot-udoo/patches/2015.10-rc5/010-tbs2910-env_settings.patch
patching file include/configs/tbs2910.h
APPLY PATCH (common - arm) /home/babboy/Openelec/Matrix/packages/tools/u-boot-udoo/patches/2015.10-rc5/020-udoo-01-env_settings.patch
patching file include/configs/udoo.h
APPLY PATCH (common - arm) /home/babboy/Openelec/Matrix/packages/tools/u-boot-udoo/patches/2015.10-rc5/020-udoo-02-reg_change.patch
patching file board/udoo/udoo_spl.c
APPLY PATCH (common - arm) /home/babboy/Openelec/Matrix/packages/tools/u-boot-udoo/patches/2015.10-rc5/030-udoo-tbs2910-usb-ums-support.patch
patching file common/cmd_usb_mass_storage.c
Yes, I will make v6.0.1 with newer kernel 3.14.54. I'm also looking the kernel from Xbian 4.3.x.maspeter wrote:could it be a problem with kernel? Do you have any solution?
