How to play Matrix with TBS Tuners.
Postby steven » Wed Dec 18, 2013 11:57 am
Hi All
If you want to play TBS tuners with Matrix you need to burn a new system
named MatrixTV which is a customize linux system added TBS tuner and XBMC/VDR support.
Here will show some picture how to use with MatrixTV system.
First Power on Matrix You will get the splash picture like this:
power on
Press any key to enter the setup dialog otherwise it will enter XBMC after 3 seconds
The main setting dialog:
Main Setting Dialog
Click Update Satellite Transponders,If your network is ok ,it will auto update satellite list to the latest:
Then Setup your Diseqc,below picture shows success detect TBS5980
Enter Diseqc Dialog
Shows success detected TBS5980
Select the Diseqc you are using:
After config the Diseqc, return to the main dialog
click Auto scan channels then it will auto scan the channels for VDR like this:
After scan all channels. Then you can start watch TV with XBMC.
Return to the main dialog click start XBMC with VDR.
Then you will see the XBMC's main dialog.
Click Live TV then you can see the channels you scaned like this:
Ok you can enjoy with MatrixTV now. :)
Any reply or advice will be appreciate. :lol:
Re: How to play Matrix with TBS Tuners.
Postby erix22 » Tue Jan 14, 2014 2:27 am
Hi Steven,
I'm getting more and more exited by this little machine..
great news from you.
Thanks again too you for all your efforts.
Regards
Erix
erix22
Postby steven » Tue Jan 14, 2014 9:29 am
erix22 wrote:Hi Steven,
Regards
Erix
You are welcome,we will continue to make good product. :)
Any question with this steps ,please feel free to send it here.
Postby matchboxx » Fri Jan 17, 2014 8:27 pm
yes work , but only FTA channels now , with scrambled channels system only buffering and stay always on 0%, i think problem with dvbapi :D
matchboxx
Postby bzoli72 » Mon Feb 10, 2014 6:03 am
Hi steven!
MatrixTV 1.0.0.2 (PCB1.3) not scan channels with TBS5925 tuner.
bzoli72
Postby steven » Mon Feb 10, 2014 5:34 pm
bzoli72 wrote:Hi steven!
Hi bzoli72
please have a try with beta V 1.0.0.3 version.
viewtopic.php?f=156&t=8831
Postby alanb2121 » Wed Mar 26, 2014 5:14 am
I can successfully scan channels and they appear in XBMC. All the FTA channels sit at 0% buffering when I try to view them. I'm using a TBS 5922 tuner
alanb2121
Postby steven » Wed Mar 26, 2014 11:16 am
alanb2121 wrote:I can successfully scan channels and they appear in XBMC. All the FTA channels sit at 0% buffering when I try to view them. I'm using a TBS 5922 tuner
Hi alanb2121
Please have a try with our latest MatrixTV V1.0.0.5:
http://sourceforge.net/projects/matrixt ... p/download
Postby alanb2121 » Wed Mar 26, 2014 12:08 pm
Awesome, I'll download it and check it out.
Do you have a list of the changes?
alanb2121
Return to General discussion
