More than 1 dvb/s/t/c in Matrix
Postby dubaisatshop » Fri Aug 15, 2014 7:53 pm
Any idea about connecting more than 1 dvb-s/s2, dvb-t or dvb-c USB device to Matrix at the same time ?
dubaisatshop
Re: More than 1 dvb/s/t/c in Matrix
Postby piotrasd » Sat Aug 16, 2014 2:07 am
hub USB ?
piotrasd
Postby updatelee » Sat Aug 16, 2014 8:02 am
I use a USB 3.0 hub on a USB 3.0 port on my computer to run 4 DVB adapters off one port, works fine. Now the Matrix is USB 2.0 but still should have enough bandwidth to run 4, I just never tried it. Give it a go and report back.
Postby diabloss » Sat Aug 16, 2014 4:31 pm
i used on all 3 usb ports 2 suntek's tuners (cable + sat) and 1 TBS tuner ... all 3 were working fine , a bit of heat but were working fine.
diabloss
Postby dubaisatshop » Mon Aug 18, 2014 6:11 pm
diabloss wrote:i used on all 3 usb ports 2 suntek's tuners (cable + sat) and 1 TBS tuner ... all 3 were working fine , a bit of heat but were working fine.
Is it mean can stream from 3 attached USB devices to different clients simultaneously?
dubaisatshop
Postby diabloss » Mon Aug 18, 2014 7:05 pm
Yes
diabloss
Return to General discussion
