Can'to flash MatrixTV 1.0.1.0 over Ubuntu 12.04
Postby mikebzh44 » Thu Oct 16, 2014 12:59 pm
Hi.
I was trying different OS provided by TBS so I flash Ubuntu 12.04.
But now, I can't flash MatrixTV 1.0.1.0 over Ubuntu :(
I'm using USB cable method, everything is OK but when I reboot I'm always on Ubuntu :evil:
And I can't flash OpenELEC :
* download OpenELEC-TBS.arm-devel-20140807170606-r18774-g2c40356
* execute MfgTool2.exe
* get this error :
* in mfgtool.log :
DLL version: 2.2.3
Thursday, October 16, 2014 06:57:53   Start new logging
ModuleID[2] LevelID[1]: Error: Can't find the specified list(SabreSD-eMMC-use-batch-file) in the xml file
ModuleID[2] LevelID[1]: Parse ucl script failed, error code: 12
mikebzh44
Re: Can'to flash MatrixTV 1.0.1.0 over Ubuntu 12.04
Postby vpeter » Thu Oct 16, 2014 2:38 pm
mikebzh44 Wrote:And I can't flash OpenELEC :
* get this error :
* in mfgtool.log :
For OpenELEC don't run MfgTool2.exe! Run correct .bat file (MfgTool2-reinstall_vX.bat). You get that hint from mfgtool.log file also (use-batch-file).
vpeter
Postby mikebzh44 » Thu Oct 16, 2014 3:42 pm
OK.
And how can I remove Ubuntu ? Because even after flashing MatrixTV 1.0.1.0 over Ubuntu when I power on the case, it's always Ubuntu :(
mikebzh44
Postby vpeter » Thu Oct 16, 2014 4:39 pm
mikebzh44 Wrote:And how can I remove Ubuntu ? Because even after flashing MatrixTV 1.0.1.0 over Ubuntu when I power on the case, it's always Ubuntu
Flashing something overwrites what's already in eMMC. Seems you didn't flash correctly.
vpeter
Postby mikebzh44 » Thu Oct 16, 2014 4:57 pm
I will make some screenshot but :
- the box was running this MatrixTV release :
[img width=630 height=354]http://i.imgur.com/b6tB5Fzl.jpg[/img]
I thought it was the latest release (1.0.1.0) because I have flash it several times but a french user who has also flash V1.0.1.0 get this compiled date :
xbmc 13.2-beta1 (Compiled: Aug 30 2014)
But, I have successfully flash Android over MatrixTV then Ubuntu over Android. So maybe that MatrixTV-V1.0.1.0.zip is not OK. I will redownload it from sourceforge.
mikebzh44
Postby vpeter » Thu Oct 16, 2014 5:00 pm
When using MfgTool2 you will see if flashing was done correctly. Also you can checl log file.
vpeter
Postby mikebzh44 » Fri Oct 17, 2014 2:29 am
After using this image :
viewtopic.php?f=155&t=8859&start=80#p32005
Ubuntu was replace by OpenELEC.
Will give a try to MatrixTV 1.0.1.0 if I've got time ;)
Thanks.
mikebzh44
Postby mikebzh44 » Fri Oct 17, 2014 4:13 am
Just to give another try with MatrixTV 1.0.1.0, I have reflash it over OpenELEC Gotham :
For me, this flash is OK. Here is mfgtools.log : http://pastebin.com/ttQb39Ci
But when booting the box, I have this message and the boot stop :
I have redownload and reflash MatrixTV 1.0.1.0 from sourceforge with no effect.
So I have flash 1.0.0.9 but the flash took longer and log is different :
http://pastebin.com/AJzgJC4q
And MatricTV 1.0.0.9 boot successfully :S
mikebzh44
Postby vpeter » Fri Oct 17, 2014 2:56 pm
I think you suffer from this issue
viewtopic.php?f=155&t=9106
There is an error in this image - only updates kernel without root filesystem. Open file cfg.ini and change
name = SabreSD-eMMC-kernel
to
name = SabreSD-eMMC
Then install again.
Seems someone from TBS didn't read my post and fix the image. Or there are just 3 matrixtv users out there :lol:
vpeter
Postby mikebzh44 » Fri Oct 17, 2014 3:24 pm
Thanks. I will try this as soon as possible.
mikebzh44
Return to Install and setup
Users browsing this forum: No registered users and 21 guests
