in the config of the build env (booth as well matrixtv as openpctv) inside config/platforms/arm/imx6/packages/linux/build you have :
- Code: Select all
if pkg_uses $1 tbskernel; then
wget http://sourceforge.net/projects/openpctv/files/packages/imx/uImage_$(kernel_version)/download \
-O .install/boot/$IMAGE || cp arch/$TARGET_ARCH/boot/$IMAGE .install/boot
else
fi
the precompiled uImage is buggy, this "if" should be removed..
Unfortunatelly I coudn't find your code for the fan controll, I see only in the latest patch there are some exclusion from current gpio kernel assignments for that but no additional code for it.
Thanks a lot
miro
