Re TBS Recorder
Re TBS Recorder
Postby sdaar » Tue Jan 12, 2016 1:22 am
I am using TBS6983 + TBS Recorder software. When I record stream to file the program records a single file and stop working. It will be better TBS Recorder to record files sequentially instead of recording a single file. For example, user selects a folder and size of the file. When the size of that file reached to the size entered by user, another file should be created and stream should be written in that file. In this way different files whit same size should be created in the output folder. If you add this option i will be very helpful. Thank you in advance!
sdaar
Return to Development
