tbs5680 not working on debian
Postby marianpopeanga » Tue Apr 02, 2013 9:31 am
Hi All,
I am a recent customer of tbs5680 external usb tunner. I have upgraded my linux kernel to 3.7.10 with DVB support.
I applied latest tbs patches for this card downloaded from the web site here.
The card is detected and the interface shows up.
The problem that i am facing is that no channel is detected, no matter what i do.
On the same box i also have vmware with Windows XP. From the vmware and windows, i am able to scan the channels and see thm, thought dvb dream or vlc.
So everything looks fine with the signal, it seems a problem related to the Linux OS in particular.
I even tried to tune the frequency in VLC with the ones found on Windows. Those channels don't open on linux.
The question that i have is: is linux supported and if so which kernel version should i use for those drivers.
Are there any knows issues?
Thanks,
Marian
marianpopeanga
Re: tbs5680 not working on debian
Postby updatelee » Tue Apr 02, 2013 10:01 am
oi vlc should never be used for tuning, its horrendous.
what application are you using to scan?
Postby marianpopeanga » Tue Apr 02, 2013 10:09 am
I have tried: scan, w_scan.
I am not sure why no channel is detected at the frequencies i saw on windows.
marianpopeanga
Postby updatelee » Tue Apr 02, 2013 11:18 am
try scan-s2?
If you just want to test tuning, not scanning, then you can try my tune-s2 app
https://bitbucket.org/updatelee/tune-s2
Postby marianpopeanga » Tue Apr 02, 2013 11:30 am
Sure. I'll try it. I just thought scan_s2 it is only for satelite connections, so i just looked briefly on it
I'll try also the tune_s2 tool.
The scan_s2 should work dvb-c? This is the normal way for this device to scan the channeles?
marianpopeanga
Postby updatelee » Tue Apr 02, 2013 12:24 pm
sorry my bad, I miss read the model number. Both those apps are for satellite.
There is no dvb-c here in NA so I havent a clue what apps to use.
Postby marianpopeanga » Tue Apr 02, 2013 3:33 pm
It will be good if some developer can give some insight about those issues on Linux.
Are them expected ? On which kernel version this is supposed to work, I am wondering if there is some kernel setting that
prevents this to work correctly.
marianpopeanga
Postby marianpopeanga » Fri Apr 05, 2013 8:16 am
This the error that i get for a simple scan, in case there will be peoples getting into similar issue:
scan dvbc.conf
scanning dvbc.conf
initial transponder 322000000 6875000 0 5
initial transponder 322000000 6875000 0 3
>>> tune to: 322000000:INVERSION_AUTO:6875000:FEC_NONE:QAM_256
WARNING: filter timeout pid 0x0010
>>> tune to: 322000000:INVERSION_AUTO:6875000:FEC_NONE:QAM_64
WARNING: >>> tuning failed!!!
>>> tune to: 322000000:INVERSION_AUTO:6875000:FEC_NONE:QAM_64 (tuning failed)
dumping lists (0 services)
Done.
cat dvbc.conf
C 322000000 6875000 NONE QAM256
C 322000000 6875000 NONE QAM64
anyone knows that this warning mean:
'WARNING: filter timeout pid 0x0000' ?
marianpopeanga
