Oscam SVN for MOI+
Oscam SVN for MOI+
Postby costan » Wed Oct 26, 2016 10:55 pm
the last OSCAM *SVN* version.
I checked it on my box, is working since weeks
http://www.costan.org/moiplus/oscam-svn11272
Use at YOUR OWN RISK.
Don't use if it's not legal in your contry. I hereby disclaim any responsibility to the end user.
Just drop the binary under /usr/local/sbin, and put all the oscam config and Softcam.Key file under /usr/local/etc.
Use a startup script under /etc/init.d to have it started on boot.
Mine looks like this:
Code: Select all
#!/bin/sh
# Oscam        Starts Oscam
start() {
        echo -n "Starting OSCam: "
        /usr/local/sbin/oscam -b
        echo "OK"
stop() {
        echo -n "Stopping OSCam: "
        killall oscam
        echo "OK"
restart() {
        stop
        start
case "$1" in
  start)
        start
  stop)
        stop
  restart|reload)
        restart
        echo "Usage: $0 {start|stop|restart}"
        exit 1
esac
exit $?
Happy OSCamming.
costan
Re: Oscam SVN for MOI+
Postby MariuCh » Mon Oct 23, 2017 4:43 am
Hi Costan,
I'm using your tvheadend and oscam versions.
For some time on several channels I have been observe video / audio freeze while refreshing ecm keys.
I'm looking for information and I find some that may be the oscam version and the dvbapi protocol problem.
Can you compile a newer version of oscam?
Regards,
MariuCh
MariuCh
Return to MOI+
