How to update MOI+?
1. Download the latest software (system, kernel or u-boot) from:
http://www.tbsdtv.com/download/
2. Copy the software that you want to update to a USB flash drive (min. 1GB), for example, if you just need to update the kernel, then download only the latest kernel and copy it to the USB flash drive, if you copy all of the three files: system, kernel and u-boot, to the USB flash drive, MOI+ will update all of them and it will take a bit longer.
3. Make sure your MOI+ is powered off, connect the USB flash drive to it, and then power on, the update will start, on the LCD screen it dispalys:
- "Welcome MOI+"
- When updat the u-boot, it shows the u-boot loading progress in percentage (%)
- when update the kernelit shows the kernel loading progress in percentage (%)
- when update the system, it shows the system loading progress in percentage (%) and "Reading, please later..."
4. After the update completes (takes about 5 minutes), the IP address will be displayed on the LCD screen, make sure the network cable is connected.
NOTE:
There is no need to restart MOI+ after the update.
To check the version, you can go to the web user interface by entering the IP address displayed on the LCD screen to the address bar of the browser.
